I have a plate system on my car that I have not finished or tried yet, it is NOS brand plates with jets in the outboard plates only. The center plate has no provision for the squeeze. I need to mount the solenoids and run the line from the bottle to the NOS solenoid and run the fuel line from the fuel four port fuel regulator to the fuel solenoid. I have a Magnafuel 300 pump with a four port BG regulator set at 6.5lbs, I will reset the pressure with the fuel solenoid activated free flowing the fuel line to the plate disconnected and ran into a jug
That is the way that NOS tech said to do that, they also said that my fuel system should support the hundred HP tune up I plan on running. IHTHs
