Trans Service after 82000 miles? #596159
01/28/10 12:26 AM
01/28/10 12:26 AM
Texas
chuck2112 Offline OP
Texas
For some reason I failed to service the transmission in my PT Cruiser and it now has 82000 miles on it. I am having no problems but I have been told that if I put a new filter and fluid in it, it will go out quick. Is this true?
Re: Trans Service after 82000 miles? [Re: chuck2112] #596160
01/28/10 07:52 AM
01/28/10 07:52 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
If there is an internal problem, it will make it happen sonner than later.
if there's no problems you'll be fine
Re: Trans Service after 82000 miles? [Re: gtx6970] #596161
01/28/10 07:54 AM
01/28/10 07:54 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Change it. Synthetic.
Re: Trans Service after 82000 miles? [Re: DennisH ] #596162
01/28/10 10:09 AM
01/28/10 10:09 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I would not change it.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Trans Service after 82000 miles? [Re: GoodysGotaCuda] #596163
01/28/10 10:44 AM
01/28/10 10:44 AM
Texas
Texas
Goodysgotacuda,
Thanks for your response to my transmission service question. I would like more of your opinion on leaving the old fluid and filter in it. I don't know much about transmissions. The reason I am specifically replying to you is because of your awesome car. When I was a kid my next door neighbor bought one exactly like yours. I loved that car. The black racing stripes were shaped perfect on the bright yellow in my mind. He put crager slots on it and it had black sidepipes. He had a 340 in it and would take it to the "local illegal" racing strip. He always told me that he could take the 350 camaros everytime if the race started with a rolling start. Please tell me more about my transmission service.
Thanks and congratulations on having that bad ass car!
Chuck
Re: Trans Service after 82000 miles? [Re: chuck2112] #596164
01/28/10 10:52 AM
01/28/10 10:52 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks Chuck, my opinion will be right or wrong depending on who you ask. But, I am a believer with not servicing a trans for that long of a period the clutch material that is floating in that fluid is actually helping the clutches hold. Flushing that fluid for fresh, clean fluid could help promote the clutches in the trans slipping, therefore 'causing' it to have problems soon after the fluid change.
Just my opinion! Thanks for the comments on the car.
2020 RAM 1500
Re: Trans Service after 82000 miles? [Re: GoodysGotaCuda] #596165
01/28/10 12:29 PM
01/28/10 12:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
PT transmissions are not happy with old burnt fluid. I have two of them, an 03 limited and an 05 Gt convert. The 03 got changed at 35,000 and the GT at 72,000 with no trouble from either afterward. I'd recommend going ahead and changing it. These aren't our old 904/727s. Here';s a great place to ask about PTs. http://www.ptcrew.com/?sid=9174b31ec2120977e2c7e5bd98adb784
Re: Trans Service after 82000 miles? [Re: GoodysGotaCuda] #596166
01/28/10 12:32 PM
01/28/10 12:32 PM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
I have been told the same thing about fluid changes. A tranny guy told me (At the time my vehicle had 160,000 miles on it- much more than yours) that over time varnish and such can build up and actually provide a seal for excessive tolerances. Fresh fluid can wash this away causing problems. Again this is what I was told. Im not a mechanic. My current daily driver has 200,000 miles. The same guy said to not change fluid and filter just keep an eye on the fluid level and be nice to it. I asked about just changing the filter and reusing the fluid but he pointed out there is no real way to catch the used stuff and keep it dirt and gunk free. (No drain plug in pan)
Keep old mopars alive.
Re: Trans Service after 82000 miles? [Re: 2boltmain] #596167
01/28/10 01:08 PM
01/28/10 01:08 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i have been changing mine every year 10k or so miles has 250k now.. cheaper to maintain it.. dan
Re: Trans Service after 82000 miles? [Re: ph23vo] #596168
01/28/10 01:37 PM
01/28/10 01:37 PM
P
Paul_Fancsali Offline
P
If you do CHANGE IT DO NOT FLUSH IT!I cannot really emphasis this more, don't care about residual fluid left
Re: Trans Service after 82000 miles? [Re: Paul_Fancsali] #596169
01/28/10 01:59 PM
01/28/10 01:59 PM
Texas
Texas
Paul,
When you say "don't care about residual fluid left", are you saying to not drain the torque converter and just replace the filter and fill it back up with fresh fluid?
Re: Trans Service after 82000 miles? [Re: chuck2112] #596170
01/28/10 02:51 PM
01/28/10 02:51 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Change it, and run whatever is currently in it=Mopar ATF fluid. I have done this on many high mileage transmissions with no probelms.
Re: Trans Service after 82000 miles? [Re: chuck2112] #596171
01/28/10 04:29 PM
01/28/10 04:29 PM
P
P
Yes just change what in the pan/ filter that conv probably does not have drain anyway. I have seen 7 vehicles trans fail right after a so called flush most with only 30-50K.
Re: Trans Service after 82000 miles? [Re: Paul_Fancsali] #596172
01/28/10 05:47 PM
01/28/10 05:47 PM
northeast texas
strokin73cuda Offline
northeast texas
Lots of good replies here, If it has no problems now change it I have done the same thing in the past the latest my wifes truck had over 90,000 when it was changed (not flushed) and now it has over 125,000 with no inherent problems. Most of the time someone decides to change thier fluid it is because the trans has started having an issue of some sort, so they change the fluid and this doesn't fix what was wrong it only leads to the trans still having a problem and eventually self destructing while still driving the vehicle waiting on it to fix itself.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Trans Service after 82000 miles? [Re: strokin73cuda] #596173
01/29/10 03:08 PM
01/29/10 03:08 PM
Texas
Texas
Thank you folks very much!
Re: Trans Service after 82000 miles? [Re: chuck2112] #596174
01/29/10 04:56 PM
01/29/10 04:56 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
I had a 93 Lebaron cvt. 3.0, though can't remember which trans....anyway I bought the car with 42K on it, drove it without problem to 120K (perhaps the trans was a little 'soft' shifting) I then had the fluid and filter changed....It was NOTICEABLY slipping, I was concerned whether I'd make it home (changed with mopar atf). Next day drove to trans shop...$1600 and drove fine till I sold it with 270K. So just be where, do you have an emergency fund?
Re: Trans Service after 82000 miles? [Re: MoparDan] #596175
01/29/10 05:05 PM
01/29/10 05:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Key there is that you did your first trans fluid change at 120K. After 80K to 100K on the fluid don't touch it.
Now, ph23vo changes his fluid real agressive schedule (I assume he does it himself). And he got 250K miles out of his trans. A lot more than the 150K and counting you got out of your second/rebuilt trans.
Re: Trans Service after 82000 miles? [Re: autoxcuda] #596176
01/29/10 08:10 PM
01/29/10 08:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
line A
Folks , if changing the fluid and filter at 82K causes slipping problems, it was on it's way out anyway, you just sped up the inevitable
Line B - ck the fluid condition before you do anything , if it smells burnt - your to late - see line A
