Re: 416 combos
[Re: Voluster]
#594462
01/26/10 01:53 PM
01/26/10 01:53 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Well I'm running a 422" which is a 4.10 bore with 4.00 stroke. At 2920lbs it's gone 6.20@109. This is with very little tuning. Should be a solid 6.0-6.10 car soon. Indy 360-2 heads and intake, custom Diamond dome pistons, ect.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 416 combos
[Re: Voluster]
#594464
01/26/10 02:40 PM
01/26/10 02:40 PM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
I'm running a 408 in my Aspen 3420# w/driver and runs 10.76 @ 123. with a best 1.41 60' but with 4.30 gears & 30" hoosiers.KB744 pistons,forged scat I beams,forged Scat crank,mildly ported Eddy heads,590MP cam,Super Victor,750hp,TTI step up headers.I'd like to get a 950hp from Bigs and see how that would pick it up.Now that TTI has 1 7/8" headers for these cars i should start saving for that upgrade as well. Vid on You Tube in my sig
Re: 416 combos
[Re: 77DragracerR/T]
#594465
01/26/10 03:08 PM
01/26/10 03:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my combo is a 416 4.070x4.00 with ported Indybrocks and a baby roller 246/254 @ 50 with .590 lift car weights 2961 and it has gone 6.50/105 in the 1/8 and 10.35/130 in the 1/4. 60' 1.041 with 4.88 and 32x14 M/T running a Q950
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 416 combos
[Re: Voluster]
#594467
01/26/10 03:38 PM
01/26/10 03:38 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Replcae that carb. Way too small. I start at 870 wet flowed on a 4" arm and those are fairly mild. Bigger is better on the stroker engines in terms of carbs.
Re: 416 combos
[Re: Voluster]
#594469
01/26/10 03:39 PM
01/26/10 03:39 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I had a 416 with moderately ported eddies,( maxed at 275) flat tappet( 260@ 50) 11.8 compression, weiand excellerator, 1000cfm race demon, dinky tti headers, 4900 flash convertor, all in a column shifted, bench seat, 3400 pound car with leafs and went 10.74 with it.I drove that combination 40 miles each way to the track several times to race it. personally i dont think the m1 is the best choice of intakes( like the excellerator or victor both much better) and it likely will run better with a 950ish carb on it, but you will be mighty impressed with its performance possibilities. ![](/ubbthreads/images/graemlins/beer.gif)
Re: 416 combos
[Re: Voluster]
#594471
01/26/10 05:19 PM
01/26/10 05:19 PM
B3422W5
Portage,michigan
Why do you say the M1 intake is no good? I don't see much difference from the victor. They are both single planes
Not afraid of trying a bigger carb just gotta get the motor together
i didnt say it was " no good" i said i like both the victor and excellerator better( both those are single planes as well)my personal choice is one of the above, and i have used both. IMO, they both have better fuel distribution.
most " standard headed" good running smallblocks i have seen dont run the M1. thats just my personal observation and opinion, nothing more.
just cause Mopar makes it doesnt make it the best choice. i currently have a w5 motor, the last choice i or most anybody i know to run on a w5 would be either of the mopar w5 intakes. just food for thought is all. but hey if you have it run it, its not like there is a huge difference you are going to see with any of them. you just asked for opinions, and i gave you mine, thats all ![](/ubbthreads/images/graemlins/beer.gif)
Re: 416 combos
[Re: B3422W5]
#594472
01/26/10 09:08 PM
01/26/10 09:08 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
416 cubic inch,W8 heads,3050 pounds,10 inch tire,8000 stall converter..runs 5.60's in the 1/8 8.90's in the 1/4 on bad tune in the heat N/A. Motor is for sale ![](/ubbthreads/images/graemlins/grin.gif)
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Re: 416 combos
[Re: Voluster]
#594474
01/26/10 09:44 PM
01/26/10 09:44 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
not a 416 but a 408, 40 over 360 block,eagle internals, 13/1 comp, ported eddys, victor man, roller cam, 950 carb, 5200 vert w/727, 8 3/4 410 gears, 3000# best run in sig, havent really tweaked it all out yet
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: 416 combos
[Re: 72demon416]
#594480
01/28/10 07:48 PM
01/28/10 07:48 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Duh...I just noticed my sig and realized that my old mill was a 416 and I could probably contribute to this post and even stay on topic ![](/ubbthreads/images/graemlins/laugh2.gif) 10.3-1 comp- ross pistons eagle h-beams, MP forged crank ported 1'st gen w2's 1.6 jesels- 2.08/1.60 Victor W2 340 intake w/ 1" spacer Mighty demon 825 TTI step tube headers with full exhaust& x-pipe 1.6 jesels- 2.08/1.60 valves Comp solid flat tappet 260/266 586/597 112 c/l 12lb flywheel I don't know what the car weighs but I'm thinking 3500-3600 for sure with 4'spd and 4:10's & 26.1 tire. Et's were all over the map but mph was 120-122 on any given day. Idled relatively smooth- sounded like a healthy 340 Was a awesome combo till I blew it up... ![](/ubbthreads/images/graemlins/eyes.gif)
