Re: 416 combos
[Re: Voluster]
#594462
01/26/10 01:53 PM
01/26/10 01:53 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Well I'm running a 422" which is a 4.10 bore with 4.00 stroke. At 2920lbs it's gone 6.20@109. This is with very little tuning. Should be a solid 6.0-6.10 car soon. Indy 360-2 heads and intake, custom Diamond dome pistons, ect.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 416 combos
[Re: Voluster]
#594464
01/26/10 02:40 PM
01/26/10 02:40 PM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
I'm running a 408 in my Aspen 3420# w/driver and runs 10.76 @ 123. with a best 1.41 60' but with 4.30 gears & 30" hoosiers.KB744 pistons,forged scat I beams,forged Scat crank,mildly ported Eddy heads,590MP cam,Super Victor,750hp,TTI step up headers.I'd like to get a 950hp from Bigs and see how that would pick it up.Now that TTI has 1 7/8" headers for these cars i should start saving for that upgrade as well. Vid on You Tube in my sig
Re: 416 combos
[Re: 77DragracerR/T]
#594465
01/26/10 03:08 PM
01/26/10 03:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my combo is a 416 4.070x4.00 with ported Indybrocks and a baby roller 246/254 @ 50 with .590 lift car weights 2961 and it has gone 6.50/105 in the 1/8 and 10.35/130 in the 1/4. 60' 1.041 with 4.88 and 32x14 M/T running a Q950
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 416 combos
[Re: Voluster]
#594467
01/26/10 03:38 PM
01/26/10 03:38 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Replcae that carb. Way too small. I start at 870 wet flowed on a 4" arm and those are fairly mild. Bigger is better on the stroker engines in terms of carbs.
Re: 416 combos
[Re: Voluster]
#594469
01/26/10 03:39 PM
01/26/10 03:39 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I had a 416 with moderately ported eddies,( maxed at 275) flat tappet( 260@ 50) 11.8 compression, weiand excellerator, 1000cfm race demon, dinky tti headers, 4900 flash convertor, all in a column shifted, bench seat, 3400 pound car with leafs and went 10.74 with it.I drove that combination 40 miles each way to the track several times to race it. personally i dont think the m1 is the best choice of intakes( like the excellerator or victor both much better) and it likely will run better with a 950ish carb on it, but you will be mighty impressed with its performance possibilities.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: 416 combos
[Re: Voluster]
#594471
01/26/10 05:19 PM
01/26/10 05:19 PM
B3422W5
Portage,michigan
Why do you say the M1 intake is no good? I don't see much difference from the victor. They are both single planes
Not afraid of trying a bigger carb just gotta get the motor together
i didnt say it was " no good" i said i like both the victor and excellerator better( both those are single planes as well)my personal choice is one of the above, and i have used both. IMO, they both have better fuel distribution.
most " standard headed" good running smallblocks i have seen dont run the M1. thats just my personal observation and opinion, nothing more.
just cause Mopar makes it doesnt make it the best choice. i currently have a w5 motor, the last choice i or most anybody i know to run on a w5 would be either of the mopar w5 intakes. just food for thought is all. but hey if you have it run it, its not like there is a huge difference you are going to see with any of them. you just asked for opinions, and i gave you mine, thats all
Re: 416 combos
[Re: B3422W5]
#594472
01/26/10 09:08 PM
01/26/10 09:08 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
416 cubic inch,W8 heads,3050 pounds,10 inch tire,8000 stall converter..runs 5.60's in the 1/8 8.90's in the 1/4 on bad tune in the heat N/A. Motor is for sale
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
Re: 416 combos
[Re: Voluster]
#594474
01/26/10 09:44 PM
01/26/10 09:44 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
not a 416 but a 408, 40 over 360 block,eagle internals, 13/1 comp, ported eddys, victor man, roller cam, 950 carb, 5200 vert w/727, 8 3/4 410 gears, 3000# best run in sig, havent really tweaked it all out yet
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: 416 combos
[Re: 72demon416]
#594480
01/28/10 07:48 PM
01/28/10 07:48 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Duh...I just noticed my sig and realized that my old mill was a 416 and I could probably contribute to this post and even stay on topic 10.3-1 comp- ross pistons eagle h-beams, MP forged crank ported 1'st gen w2's 1.6 jesels- 2.08/1.60 Victor W2 340 intake w/ 1" spacer Mighty demon 825 TTI step tube headers with full exhaust& x-pipe 1.6 jesels- 2.08/1.60 valves Comp solid flat tappet 260/266 586/597 112 c/l 12lb flywheel I don't know what the car weighs but I'm thinking 3500-3600 for sure with 4'spd and 4:10's & 26.1 tire. Et's were all over the map but mph was 120-122 on any given day. Idled relatively smooth- sounded like a healthy 340 Was a awesome combo till I blew it up...
