Re: Automatic shifters? [Re: rattler] #594299
03/22/10 09:51 PM
03/22/10 09:51 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Another
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Automatic shifters? [Re: rattler] #594300
03/22/10 09:53 PM
03/22/10 09:53 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Last one.The shifter is setting at the drive position in these pics. At park it is close to the dash and in low it is close to the console.
Re: Automatic shifters? [Re: rattler] #594301
03/22/10 11:19 PM
03/22/10 11:19 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
weird sounding tranny tail shaft,,,i think we talked before jeep seats in ur truck ??
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: fstfish66] #594302
03/23/10 08:46 AM
03/23/10 08:46 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Yes, the seats are from a 98? grand cherokee, and the console came from a durango.
Re: Automatic shifters? [Re: rattler] #594303
03/23/10 03:15 PM
03/23/10 03:15 PM
scratchnfotraction Offline
I am useing a BB 727 short shaft bolt on yoke in my 88 440 truck..engine is in the sig pic
the u-joint is 4" across with 1 1/4" round caps
measure the tranz mount distance from back of case
I had to move the xmember forward 2" in my truck..after building a xmember out of some square stock and lower brakets
a reg long tail shaft 727 or a reg 4x4 short 727 will have the mount center 7" from back of case
the MH short 727 will be 5" from back of case
think those MH 727 are for a 1 1/4 ton chassis
the speedo hook up is in a diff spot also when trying a stock xmember on it
I went with a full manual Vb to loose the linkage and will use a floor mount lokar shifter
I looked at a gennie shifter..but wont have room on top of tranz and floor pan
the lokar will mount inside cab on the floor and have rod linkage for the hook up
Re: Automatic shifters? [Re: rattler] #594304
03/24/10 04:40 PM
03/24/10 04:40 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i like the seat,,hope to find a set as nice
2015 cherokee
2013 R/T classic
