Page 2 of 4 1 2 3 4
Re: Aluminum rod, How many runs? [Re: Moore & Moore] #593894
01/26/10 09:13 PM
01/26/10 09:13 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I run GRP also and I have been told by some of the best 100 passes and out..but that is a high Hp n/a small block at 9000rpm..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Aluminum rod, How many runs? [Re: BigDog68Dart] #593895
01/26/10 09:56 PM
01/26/10 09:56 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Thank you all for your replies, I think I will order a new set just to be on the safe side, even though the engine is diapered, you never know what will happen and would rather error on the side of caution!
I ran the BME's, MGP's, and GRP's. The BME's are supposed to be good for 200 run, according to BME. I know some Mopar guys in Arizona, that make around 1000 HP, and run 7800RPM, that run them 600-1000 runs. They always have. The MGP' and GRP's I have personally run 250 with no issues. After talking to Best Machine, I wish I hadn't thrown them away. they said they re-size and re-pin them, and they go for 400-500 passes before replacing them, and have for years. Those guys have been around for a while and only run big HP mopars, so I would trust what they say. That being said there's no telling when any connecting rods with fail. There is no way to test them except the size on the big and small end. Call them if you like, but like they told me, if you can afford it buy new ones. If not they will check size and fix them if needed. Hope this helps.
Re: Aluminum rod, How many runs? [Re: camastomcat] #593896
01/27/10 12:01 AM
01/27/10 12:01 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I made 400 runs on a 700HP 451 that I turned 7600-7800. When the BME rod broke just above the bolt, it took out everything except one head. When the cam broke in 3 pieces, it took out the aluminum timing cover and Hilborn pump. It was worse than any steel rod failure I've ever seen. Aluminum rods just don't seem necessary these days??
RIP
Re: Aluminum rod, How many runs? [Re: sixpakdodge] #593897
01/27/10 02:10 AM
01/27/10 02:10 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
There are BBC racers over on DragRaceResults with 600+ on the GRP's.
And there are many that we watch being swept up as aluminum rocks off the race track that have less than 200 runs. A freind of mine runs T/S with a 632 Chevy and changes them after 150. I think broken aluminum rods cause more oil downs than anything else. Aluminum rods are why engine diapers were invented. Aluminum is Aluminum no matter whos name is on them. Some may be slightly better than others but still aluminum.
I am not a gambler. I would only use them in a quick 16 motor and limit them to 200 or less passes. A 4 round race with 3 qualifing passes it will take a couple years to get 200 passes. If you over rev the motor take them out and scrap them before they scrap your whole motor no matter how many runs are on them.
Herb Mcandless once told me if I take them out with 300 passes to give them to him and he would run them for another 300.
Alot of different opinions on this subject. If I had a $5000 Indy Max block I would try to protect my investment and go the conservative route.
Re: Aluminum rod, How many runs? [Re: qwkmopardan] #593898
01/27/10 02:14 PM
01/27/10 02:14 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Geez after reading this post I can't understand why anyone
Would want to run aluminum rods. Seems like a huge waste of money
Hell one guy has over 100 rods laying around!!! That's got to be
Over $10,000 worth. Could have installed twin turbos with all that wasted money
Why not just buy a set of Oliver billet steels and be done with it??
Re: Aluminum rod, How many runs? [Re: Big B] #593899
01/27/10 05:02 PM
01/27/10 05:02 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I an N/A application, I've seen more failures with steel than aluminum, and I wouldn't think you would run steel in a turbo deal with big boost? Look at what people run in 1000 HP stuff, and what holds up. I had a failure with Oliver billet rods ($1470 from Barton) they lasted 93 passes. I run GRP aluminum rods for 250 runs ($1000), no failure. That's in S/C too, and I'm not blaming the Oliver product, but less bob weight is easier on parts IMO.
Post deleted by Defbob [Re: camastomcat] #593900
01/27/10 05:12 PM
01/27/10 05:12 PM
Re: Aluminum rod, How many runs? #593901
01/27/10 06:48 PM
01/27/10 06:48 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The bottom line seems to be the more cycles you flex the rod the sooner you need to change it, the killer question is how much flex is too much
Re: Aluminum rod, How many runs? [Re: emarine01] #593902
01/27/10 07:06 PM
01/27/10 07:06 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
That reminds me...
Steel has a point that you can flex it to where it will not cause any degradation. Flex it over the point and it starts to weaken.
With Alumininum, ANY flexing weakens it.
IIRC that is
Re: Aluminum rod, How many runs? [Re: hooziewhatsit] #593903
01/27/10 07:21 PM
01/27/10 07:21 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That reminds me...
IIRC that is
There are alot of credited engine builders that use them. This arguement could go on for weeks. I've seen alot of steel hanging out of motors too. The main thing with aluminum rods would be warm up and oil temp.
Re: Aluminum rod, How many runs? [Re: camastomcat] #593904
01/27/10 07:33 PM
01/27/10 07:33 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would think the rod/stroke ratio would have a large factor here with bob weight.
Re: Aluminum rod, How many runs? [Re: blownzoom440] #593905
01/27/10 08:49 PM
01/27/10 08:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I wouldn't run aluminum rods if you gave them to me. To many choices out there for good steel rods and all you have to do is order the rod bolt upgrade.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aluminum rod, How many runs? [Re: pittsburghracer] #593906
01/27/10 09:31 PM
01/27/10 09:31 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I wouldn't run steel rods if you gave them to me. Steel rods take all the vibration from detonation and put it into the crank. The crank is bouncing and shaking in a cast iron block. It doesn't take a rocket scientist to figure out that cast iron will crack after being beat on that much. Look at a steel rod engines main caps then look at the one running alluminum rods. Alluminum rods for me I have ran them for 15 years without ever having a rod failure. Some had over 1,000 miles on the odometer of pure drag racing.
Leon
Re: Aluminum rod, How many runs? [Re: Leon441] #593907
01/27/10 10:14 PM
01/27/10 10:14 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Leon
Good point! Why are there so many people afraid of aluminum? They are much less hard on cranks.
Re: Aluminum rod, How many runs? [Re: camastomcat] #593908
01/27/10 10:20 PM
01/27/10 10:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Toss my name in on the side of not running steel in a race motor, particularly a stock block one. Not even for free. I have used a few different brands with no issues. I ppan on replacing mine at 150-200 passes. Only as a maintenance issue, not becuase I believe they are done, as they will go in a street motor as the old ones before them have.
Re: Aluminum rod, How many runs? [Re: Al_Alguire] #593909
01/28/10 11:41 AM
01/28/10 11:41 AM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Had 80 passes on my Groden rods before breaking one in the water box. Destroyed everything but the bare heads. Now I run Carrillo steel rods.
Re: Aluminum rod, How many runs? [Re: mloboda] #593910
01/28/10 12:31 PM
01/28/10 12:31 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Had 93 passes on my Oliver rods before overheating 2 of them and killing my $1500 crankshaft. The $1470 rods fault? I don't think so, but they're junk. It the racing game.
Re: Aluminum rod, How many runs? [Re: camastomcat] #593911
01/28/10 03:23 PM
01/28/10 03:23 PM
mack Offline
mack  Offline
Had GRP's in my "small block" 396. At two hundred passes had them sized and if all OK ran another 200. Then changed them... The secret I have been told is piston to valve clearance. I ran two or three sets of rods this way with NO problems....
Mack Reeves SST 2377 FS/D 2377
Re: Aluminum rod, How many runs? [Re: mack] #593912
01/28/10 05:12 PM
01/28/10 05:12 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
How much hp are you guys running? I have a 493 that makes 730hp thats shifted at 7-7200rpm. I have Manley H-beam steel rods. I have run the rods for over 20,000 miles(over 6 years) and who knows how many passes. Would aluminum rods have lasted this long? Hell I plan on running the engine for 2 more years. That will put me close to 30,000 miles.
Re: Aluminum rod, How many runs? [Re: Big B] #593913
01/28/10 05:39 PM
01/28/10 05:39 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I shift at 7400, through the traps at 7800, 1034HP@7400 and 810FP@6200. And I know people that run aluminum rods on the street and strip. I don't know that I would do both, but people do as you can read on this post. And when you pull those steel rods out, better mag that crankshaft and check the size of the rods.
Page 2 of 4 1 2 3 4
