Re: Is there some way to compress a valve spring
[Re: BassMan]
#59334
05/18/08 09:28 PM
05/18/08 09:28 PM
putting rope through the sparkplug hole and bringing the piston to TDC works pretty well. also knocking the porcilan(sp?) off a plug and brazing a airline fitting works too.
[Re: west]
#59338
05/18/08 10:17 PM
05/18/08 10:17 PM
A valve cannot "slip down" if the valve spring/ retainer/ is all hooked up, the SPRING keeps the valve up. So if the valve is "slipped down" that means the clips must have come out?
You need to tell the whole story, here.
Also, KD tool used to make one that twisted to operate, it would work on many kinds of engines.
Keeping the valve up is easy with compressed air. Just take apart your compression gauge, or else make one from an old spark plug.
You sure you didn't break something or bend a valve?
#59339
05/18/08 10:32 PM
05/18/08 10:32 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
One thought to using a rope verses air is you don't have to worry about leaving it overnight to get parts. 440sixpack is right though, valves don't drop in the retainer, the grooves are interlocked and only fit one way. What does the cooresponding rocker look like on the contact pad?
Careful, your character's showing!
[Re: mark7171]
#59340
05/19/08 08:10 AM
05/19/08 08:10 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
hughesengines.com makes a $65 tool.
Comp cams sells the same tool and it works awesome. I'll tell you what I do (worked with my 500 wedge and Hemi), but I'm sure there will be much wailing and nashing of teeth.
First I tap all of the retainer with a socket. Then bring the piston up to top dead center for the cylinder I'm working on. Install your favorite valve spring tool. Gently pry on the spring until the valve contacts the piston. The retainer will break free and you can remove the locks. The piston stop the valve from falling in too far.
[Re: BassMan]
#59343
05/19/08 11:57 AM
05/19/08 11:57 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Thanks for the info everyone. To make a long story short, the engine got revved up to 10,000 rpm for several seconds and immediately therafter had a tapping noise. When I pulled the valve cover I found 1 rocker had about 1/8" play and the top of the valve flush with the retainer. The rocker looks good. Is there a split ring washer which holds the valve in place?
is this a stock 440 ? if so it went into valve float several thousand RPM below that with it's hydralic cam ...
there is a pair of half circle locks that set down inside retainer , for the valve to have moved down the locks are damaged or the retainer , or both .
you can buy an inexpensive compressor at a local sears store , use something to hold the valve from dropping in the cylinder ...
[Re: BassMan]
#59344
05/19/08 12:04 PM
05/19/08 12:04 PM
Posts: 21,909 Kirkland, Washington
Pacnorthcuda
The valve locks at the top of the valve look like two half-circles. When you compress the spring with force on the retainer locks will be visable and easily removed. Interesting what happened--are you thinking just the valve stem was destroyed? I am surprised the rocker looks good. Or did the lock fail? Doesn't sound like wiped lobe simply because that wouldn;t explain the top of the valve being flush with the retainer.
[Re: BassMan]
#59346
05/19/08 12:41 PM
05/19/08 12:41 PM
torkrules
I'm neurotic
I'm neurotic
10,000! Might not be a bad idea to check out a few other things (bearings, block, etc). My feeling is that 7000 would be tops unless your using ultra light weight parts, good oiling system, etc.
[Re: torkrules]
#59347
05/19/08 01:33 PM
05/19/08 01:33 PM
JohnRR
A gulag near you.
hyd cam , stock build , the valve train failure happened because of serious valve float which probably happened just under 700rpm unless this was a purpose built motor , meaning super stock or a PS drags contender .
i'd be looking at them ALL , not just that one .
damaged to the piston and valve might have occurred , a leak down test will tell you if the valve is bent and not closing from piston contact .
if its got stock 69 spec pistons i doubt there was piston to valve contact with that piston .040ish in the hole .
