Re: Race car wiring [Re: j.mcconnell] #592941
03/22/10 10:10 PM
03/22/10 10:10 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i'm sure there is but without schematics it would be hard to describe on the net.
Re: Race car wiring [Re: WILD BILL] #592942
03/22/10 10:21 PM
03/22/10 10:21 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I almost pulled the trigger on the Painless 8 circuit drag race setup today, but just couldn't swallow the price.
http://www.jegs.com/i/Painless+Performance+Products/764/50005/10002/-1
Now I may have a little different perspective on this as I worked electronic warfare systems to component level in the USAF.
I was just going to take the easy way out and buy a harness to save time. I may still do it but can't for the life of me figure out why the 8 circuit setup is so expensive.
-Dave
Try this one
http://www.summitracing.com/parts/PRF-50001/
It's the one I used. I just made my own switch panel.
The one you linked is outragous
The one he linked is outragous, but it does include a switch panel. But even so its still out ragous.
Also look at www.americanautowire.com they have some quality harnesses that are universal. I like the Highway 15 for a race car. mike
Re: Race car wiring [Re: j.mcconnell] #592943
03/22/10 11:59 PM
03/22/10 11:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
When using a ARC 8000 panel, is there a way to wire the key into the start circuit as a safety/theft deterrent? I've been thinking through it but still not sure.
Should be, Dont know the ARC 8000 panel. The IGN switch has full power. Cut the power wire to the start circut through a relay or solinoid. Power that off the IGN acc/on. Everything will be dead without the IGN energized. mike
Re: Race car wiring [Re: Sport440] #592944
03/23/10 06:35 AM
03/23/10 06:35 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I am getting ready to re-wire the Dart and I am torn between the flatpanel ARC unit and the K&R. I wired the Firebird with 2 K&R units and they are hard to beat. Everything included down the the shrink wrap with large laminated schematic. And Kevin's customer support is simply the best. But the ARC offers more switches and they can be programmed to momentary or full on. Also can be programmed on/off with ignition. I also like the flat panel as it is very thin, headroom is tight in my dart... Might have to try them this time.
Re: Race car wiring [Re: MegaDart] #592945
03/23/10 06:50 AM
03/23/10 06:50 AM
Orlando Florida
blown572dart Offline
Orlando Florida
I went the Spaghetti Menders way. The customer service was great,it has 2 pilot lights on each circuit to allow you to see power in and power out. It is all plug and play switch panel fits nicely.
Here it is completed.
Re: Race car wiring [Re: blown572dart] #592946
03/23/10 10:06 AM
03/23/10 10:06 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
switch panels
Re: Race car wiring [Re: MegaDart] #592947
03/23/10 11:39 AM
03/23/10 11:39 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
We rewired my car last summer and used a K&R.
as far as im concerned it is the best out there!
It is all labled, there are big picture diagrams,
and they will help you if you call.
They have great customer service also!!
For my money K&R is the way to go!!!
Re: Race car wiring [Re: HEMIDARTS] #592948
03/23/10 07:46 PM
03/23/10 07:46 PM
mack Offline
mack  Offline
X 2 on the K & R.... My 68 has it and my 2009 Challenger will have it also.. Did get the one with the screw terminals for the Challenger..
Mack Reeves SST 2377 FS/D 2377
Re: Race car wiring [Re: WILD BILL] #592949
03/23/10 09:15 PM
03/23/10 09:15 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Bill, can you share a pic of your home made switch panel for all to see? mike
Re: Race car wiring [Re: Sport440] #592950
03/24/10 01:17 AM
03/24/10 01:17 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Do any of these companies sell a fuse box or Fuse panel separately??
AL...
Alan Jones
Re: Race car wiring [Re: LA360] #592951
03/24/10 07:28 AM
03/24/10 07:28 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
AL...
Painless does sell a universal 12 and 18 circuit fuse block as well as a weather proof 20 circuit. But if you think about adding in the cost of wire and then all the terminals that come with the kit it is cheaper to get a universal harness.
Back in the swing of things at Painless again! Great to be back!
Re: Race car wiring [Re: BJS racing] #592952
03/24/10 08:21 PM
03/24/10 08:21 PM
LA360 Offline
LA360  Offline
AL...
this is true, but I already have all the rolls of wire and terminals already.
Do ARC or K&R sell fuse panels separately?
AL...
Alan Jones
Re: Race car wiring [Re: LA360] #592953
03/25/10 07:25 AM
03/25/10 07:25 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
AL...
AL...
They mostly deal with just race related stuff. I know that ARC at least used to sell a switch panel that didn't have any wiring off of it. They used printed circuit board technology and I hated it. I mounted the one I had in the dash and every time I had to pull the stupid thing out to do something I HAD to disconnect the battery or it would arc against the dash and cause more problems. The one big thing I do not like about K&R or ARC is printed circuit boards. If they go bad you have to send them back or buy a new set up. The painless stuff I can fix no matter what happens with it. It is wire, terminals, and relays with fuses. A lot easier to fix and specially if something happens at the track.
