ARP main studs in stock block 440 #592135
01/23/10 11:49 PM
01/23/10 11:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Just put new ARP main studs in my block and they stick up above the pan rail about .180". The rear ones hit the oil pan/windage tray.
OK to just trim some off that is out beyond the nuts?
Brian
Re: ARP main studs in stock block 440 [Re: '72CudaRacer] #592136
01/23/10 11:51 PM
01/23/10 11:51 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
is that with the gaskets also?
edit: i drilled a hole in the windage tray to clear the stud.
Re: ARP main studs in stock block 440 [Re: blownzoom440] #592137
01/23/10 11:55 PM
01/23/10 11:55 PM
Mooresburg, Tn
Mooresburg, Tn
No, but it doesn't look like the first gasket will be thick enough to get windage tray off the studs.
Re: ARP main studs in stock block 440 [Re: '72CudaRacer] #592138
01/24/10 12:04 AM
01/24/10 12:04 AM
ELYRIA,OH
ELYRIA,OH
like i said just drill a hole where the stud is in the tray.it wont hurt anything.
Re: ARP main studs in stock block 440 [Re: blownzoom440] #592139
01/24/10 12:12 AM
01/24/10 12:12 AM
Mooresburg, Tn
Mooresburg, Tn
That might be enough to keep it off the pan rail. The pan rail (alum) comes over it also. I was looking at a different alum pan that has the windage tray mounted on brackets welded to the inside of the pan and only used one gasket.
The pan for this car uses 2 gaskets that sandwich the windage tray. Might just work, thanks.
Re: ARP main studs in stock block 440 [Re: '72CudaRacer] #592140
01/24/10 12:20 AM
01/24/10 12:20 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
with the cut off wheel shave off a few threads
two gaskets with wintage tray was not enougth to clear the two studs
I covered my motor up ,short block was done at the time
1.39 9.85 - 137 mph
Re: ARP main studs in stock block 440 [Re: Ari440] #592141
01/24/10 01:20 AM
01/24/10 01:20 AM
Mooresburg, Tn
Mooresburg, Tn
Good to see that it ain't just me! Thanks
