Re: 4 speeds and 1/4 times....
[Re: 68LAR]
#591576
01/23/10 06:03 PM
01/23/10 06:03 PM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
I get 11.56 @ 119 shifting easier into 3rd gear due to prior carnage. 1.53 60 ft. Waiting to put a Jerico in this season. Greg. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Lawn Monkey]
#591578
01/23/10 07:22 PM
01/23/10 07:22 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
They sure are fun. I really really miss my 5-speed mustang. It ran 12.30s and was an absolute blast to drive. I also really liked the challenge of making it work on street radials. I could only muster 13.20s or so when I got it. Before I got rid of it I was going 12.70s on a regular radial tire with a 1.84 60ft just by doing better foot work ![](/ubbthreads/images/graemlins/laugh.gif) . There is a downside. I had the car for two years and broke everything behind the clutch disc other than the ring and pinion. Even twisted the splines inside the driveshaft yoke!
68 Barracuda Formula S 340
[Re: Bad340fish]
#591579
01/23/10 08:09 PM
01/23/10 08:09 PM
Posts: 999 British Columbia
toddd
British Columbia
My best is a 10.30 @131.11. I was using 1-2 Pro shifted and 3-4 face plated Hemi 4 speed. It's an absolute blast to drive. ![](http://i257.photobucket.com/albums/hh220/420Toddd/EXP_1184.jpg)
[Re: Lawn Monkey]
#591580
01/23/10 08:14 PM
01/23/10 08:14 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Sticks is fun, don't know that an auto is faster, but I suspect easier to dial in. Running a jerico & thinks its great ![](http://i977.photobucket.com/albums/ae260/oldirongreg/CarRaceStuff/milan.jpg)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: gearjammerdart]
#591582
01/23/10 10:41 PM
01/23/10 10:41 PM
Posts: 9,895 MI, usa
dvw
MI, usa
12.52@111 in my wifes Challenger. 9-1 360,224@.050 hyd roller,LD340,650 holley,full TTI exhaust,bowl ported stock 360 heads. Has O.E. 4 speed w/.244 1st gear. Needed more 1st gear ratio even w/4.30. Only parts wounded after 100 passes were the stock axles. They didn't break but were twisted 1 full spline. Doug
[Re: dvw]
#591583
01/23/10 11:36 PM
01/23/10 11:36 PM
Posts: 10,050 MN
JERICOGTX
MN
I've gone 9.85 at 137mph with a stick. SS/AH cars are running 8.40's with Jerico transmissions.
Jeff
69 GTX
68 Road Runner
[Re: SCATPK]
#591585
01/24/10 12:39 AM
01/24/10 12:39 AM
Posts: 714 USA
Lawn Monkey
USA
Thanks all I am impressed with those times ![](/ubbthreads/images/graemlins/drive.gif) ,,,, aany suggestions an the drive line of my Challenger? I have a 440 balance and 509 DC cam, stock clutch , Hemi 4 speed , Six Pack drive shaft, 4:10 Dana Track Pack and slicks,,, plans are to build the motor to go faster yet not do any changes from the flywheel back,,,, ya think the gears and rear are up for the hard launches with out breaking?
[Re: 68 HEMI GTS]
#591589
01/24/10 08:15 PM
01/24/10 08:15 PM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
My son has gone 9.75 @ 136 with the Duster. 368 W2 Shady Dell motor Jerico 4 speed 5:57 Dana ![](http://i238.photobucket.com/albums/ff230/mloboda/Duster-Milan2009.jpg)
[Re: mloboda]
#591590
01/24/10 09:07 PM
01/24/10 09:07 PM
Posts: 4,573 ...gently down the stream
LAR_414
Technically a stick car is usually faster (mph) than an auto. Now as far as which is quicker,.....we can all debate that one, so who knows.
I plan on being in the neighborhood of my auto trans times, when I'm all said and done with my stick conversion. Ran 11.07 at 120 mph as a best with the auto. So far I only ran 3 times down the track with the stick, and ran a 11.9 at 120mph blowing the tires off at the line, missing 3rd gear, and then missing 4th gear, and then running out of fuel through the traps,.....So it should run pretty good when I get things sorted out.
[Re: LAR_414]
#591591
01/24/10 10:30 PM
01/24/10 10:30 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
Happy with my 11.48@119 in a fully body 70 Challenger 906 iron head 10.1 dual plane NO ROLL CAGE street car.....Oh ya 18 spline hemi box...I have had to upgrade to a Dana afer 3 8-3/4's
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
Post deleted by moparts
[Re: Lawn Monkey]
#591592
01/26/10 02:06 PM
01/26/10 02:06 PM
#591593
01/26/10 02:24 PM
01/26/10 02:24 PM
