Dome light cluster panel dimmer switch #591499
01/23/10 02:57 PM
01/23/10 02:57 PM
fullfloater Offline OP
My dome light switch on dash has gone bad ,its on a 69 b body ,its the switch whitch you roll up or down to turn on your dome light or adjust the lights on your speedo ,any ideas where i can purchase one ,tried the local parts store ,but could not come with anything ,thanks
Re: Dome light cluster panel dimmer switch [Re: fullfloater] #591500
01/23/10 03:13 PM
01/23/10 03:13 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
There are plenty of them listed on ebay. Some restored some used and even some NOS. Not sure if anyone is making brand new ones
Re: Dome light cluster panel dimmer switch [Re: fullfloater] #591501
01/23/10 04:46 PM
01/23/10 04:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Don't have to look to far click on "attachment"
Re: Dome light cluster panel dimmer switch [Re: DAYCLONA] #591502
01/25/10 12:22 AM
01/25/10 12:22 AM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
The cluster dimmer switch didn't work in my 69 GTX. I removed it and was able to fix the rheostat spring. Beware: they are very fragile. It now works fine.
I'd remove it first and see if it can be repaired. If not, the offer above seems like a good deal.
Re: Dome light cluster panel dimmer switch [Re: moparcanuk] #591503
01/25/10 01:07 AM
01/25/10 01:07 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
You can get pretty far with just some fine emery cloth.
You can get repro for 175$ here
http://www.vansauto.com/electrical.html
I can't afford this. mark
