Re: 625 AFB on 340 too rich, kinda long...
[Re: 70AARcuda]
#591458
01/23/10 10:08 PM
01/23/10 10:08 PM
Posts: 157 Winlock, Wa
fshd4it
Winlock, Wa
Tony...checked the springs @ idle, they're good. Posest...I'll get a gauge hooked up (even temporary) and see what my fuel pressure is. I took the car out for a run & remembered why it was parked so long. It used to try and die coming to a stop (not so right now), but it still has an annoying stumble when coming off idle. And while my butt dyno may not be the best, I know this thing has a lot more to give. I'm gonna spend some quality time making sure all the "little stuff" is right (choke, timing, distributor fixes, fuel press, etc) is right before getting too worked up. Thanks to all for your help so far ![](/ubbthreads/images/graemlins/bow.gif)
In order to know what you want, you'll probably have to find out what you don't want.
