Re: Need help with brake lights problem on 69 Charger.
[Re: buildanother]
#591160
01/22/10 08:41 PM
01/22/10 08:41 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Turn sig switch.
Quick test is just plug in another switch without tearing the column apart...
[Re: 1_WILD_RT]
#591161
01/22/10 08:46 PM
01/22/10 08:46 PM
Posts: 10,181 A Red State
SNK-EYZ
A Red State
Another thing to check would be the ground. Our old Mopars have a common problem getting a ground through the taillight housings. Run a separate temporary ground to the socket and see if makes any difference. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: SNK-EYZ]
#591163
01/22/10 09:03 PM
01/22/10 09:03 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
Tried that... No dice.
[Re: pinkduster]
#591164
01/22/10 09:04 PM
01/22/10 09:04 PM
RapidRobert
With a thin wire probe see if the dark green wire in the steering column turn signal pull apart connector has fire w (brake depressed)(stick it into the green wire terminal w the 2 halves still together) & if so work rearward till you find the "open". If not pull apart the connector and if the upstream half (of the green wire connection) has no fire then as said the turn signal plastic cam assy under the steering wheel.
[Re: buildanother]
#591165
01/22/10 09:08 PM
01/22/10 09:08 PM
pinkduster
Near Reading PA USA
Turn sig switch.
![](/ubbthreads/images/graemlins/no.gif)
Sadly, it looks like you are right. If I put the right turn signal on, the left brake light comes on as well. As soon as I turn the right signal off, the brake light goes out again. If I move the turn signal arm up just a little off of it's normal position, the brake light goes on.
I think the turn signal switches are being reproduced. I wonder who the best place is to buy one. Is it a pain in the azz to replace? I'll bet the steeringwheel has never been off of this car. ![](/ubbthreads/images/graemlins/crazy.gif)
[Re: pinkduster]
#591166
01/22/10 09:18 PM
01/22/10 09:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Update:
I just went down in the garage and tried the flashers (hazard lights). Only the left front works. No right front and nothing at all in the back. ALSO, the left hood turnsignal isn't working. The wire looks pretty nasty at the socket. Would any of this affect that left brake light?
There could easily be multiple issues, dirty grounds, a bad T/S switch, a bad bulb or two.. None of it would be difficult but it can be time consuming... Something that often gets things working temporarily is switching the hazard flashers on & off quickly a few dozen times & also switching the T/S lever back & forth a few dozen times.. What that will do is clean up the sliding contact surfaces somewhat... It can't hurt & it's free, I've temporarily fixed quite a few cars that way...
[Re: pinkduster]
#591168
01/23/10 12:05 AM
01/23/10 12:05 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Steve while the problem may pose itself to appear like a turn signal switch,...check anyway, but usually the Charger has problems with the bulkhead connector for the rear harness, located in the driversside kickpanel,...I've replace, or spliced out so many of those over the decades, that's usually the first place to start when tailights start going out randomly, directionals start acting up, no brake lights etc,....sometimes the connector looks good from the outside, but being small gauge wire, heats up and loosens/ and eventually corrodes the connectors inside, I find oxidation being the biggest problem in the connector
Also you didn't by chance change out the inboard bulbs in the tailights did you",...the little odd sized jobs?....I can't recall the bulb number (odd#) generally not avaliable, but sometimes the substitute can short out in the bulb housing, but still work, but cause "gremlins" electricaly,....if the problem still persists, remove the 2 inboard bulbs, see how that goes?
Mike
[Re: DAYCLONA]
#591169
01/23/10 09:35 AM
01/23/10 09:35 AM
pinkduster
Near Reading PA USA
Mike, I haven't changed any bulbs, all that stuff is as it was 13 years ago when I parked the car. I really think the problem is the turnsignal switch. If I jiggle (is that a word? ![](/ubbthreads/images/graemlins/laugh2.gif) ) the turnsignal arm up just slightly, it makes the left brake light go on. And, the turn signal arm seems to be sort of loose, or has more "play" than any of my other old Mopars. Would you agree that this sounds like the switch is the problem? Perhaps while we are at it here we could talk about a problem that this car had back when it was my daily driver. I got this car in 88 for $500 when I was 19. Just an old used car then with high miles and undesirable colors and drivetrain. ![](/ubbthreads/images/graemlins/Twocents.gif) Regardless, it was an okay deal and I bought it. Served me great as I racked up like 30,000 miles in the first year. Around 1991 or 1992 I started to have trouble with the headlights. After a night of driving, the switch would get hot and they would go out or start to flash. Usually, I could just pull over and turn the lights off for a while and then return to driving. It gradually got worse. I replaced the dimmer switch with a new one from the dealer with no change. Back then, you used to be able to go to junkyards and they actually HAD Chargers. I used to grab all the headlight switches I could get. I got to be a pro at swapping out headlight switches. ![](/ubbthreads/images/graemlins/laugh2.gif) Each switch would have varying degrees of success until finally I noticed that the connector was looking really distorted. I had my local garage (a friend of mine) cut off my connector and attach a better one. This fixed the problem for quite some time. By about 1993/94 I had picked up a beater 71 Duster Twister ($500 again ![](/ubbthreads/images/graemlins/laugh2.gif) ) so I wouldn't have to drive the Charger in the rain and snow. Parts for the Charger had started to become so expensive and hard to find, that I had feared wrecking it in foul weather. Around this time, the headlights problem came back. I remember, I used to drive with the vent window open real far to help keep the headlight switch cool if I ran late somewhere and had to drive at night. I started driving it less and less. Got other Mopars, bought a house, started a family and just got busy as hell. The Charger went into the garage one day in 1997 and didn't come out until 2010. ![](/ubbthreads/images/graemlins/shock.gif) Recently, I have read on here about checking grounds, but we did that back in the 90s and everything seemed ok unless there are more grounds than we checked. What else could it be? When I was installing the new battery last week, I did notice what looked like a bulkhead type connector in the headlight harness right along side of the battery. I was thinking about pulling it apart today and cleaning it out with electrical parts cleaner. Please keep in mind, when I starting having the headlight problems was before the internet and I pretty much had nobody to go to with problems like this except my buddy at the local garage and he seemed to be at the end of his rope with checking the ground and replaceing the switches. And, I wasn't the only Charger owner with this problem. I knew another young guy bac then with a beater 68 Charger and he had the same problem.
[Re: RapidRobert]
#591171
01/23/10 03:46 PM
01/23/10 03:46 PM
pinkduster
Near Reading PA USA
If I jiggle (is that a word? ) the turnsignal arm up just slightly, it makes the left brake light go on.
Yes that's a word. Take off the horn ring or horn button (dont know B bodies) whatever is needed to acess the long mini screw that holds the TS stalk in place & see it it's loose.
Just pulled the wheel and tried to make that screw a little tighter... No change. ![](/ubbthreads/images/graemlins/frown.gif)
[Re: pinkduster]
#591172
01/23/10 04:13 PM
01/23/10 04:13 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Hey Steve....regarding some of the Charger problems your having, they are typical of not just Chargers, but any Mopar with 40 plus yr old wiring,...tighting the screw holding the turn signal arm, is just that, just an arm moving the "cam" assy that transmits voltage signal to the corresponding terminals, if the lights are flickering/intermittent from fooling with the turn signal/flasher switch,...time for a replacement, I've gotten mine in the past from Year One, basically a Chrysler factory part, a superceeded part, some differences, but just trim the excess molded plastic away to retrofit it in your column, easy job, and just confirm wire applications/routeing before plugging it into the harness,...the Year One pn# for a 69 B Body is FD47801 list $52, it's not that hard a part to install just a PITA As far as the Lightswitch problem, I've usually seen that a lot more on the 70 Chargers, as they use a motor/relay to raise the headlite doors, rather than vacumm,... usually the wiring/ harness running from the switch connectors into the main harness gets overly hot running the headlite current, and either fuses with another wire(s), or starts desintergrating within it plastic covering, usually a real pain unwrapping/following/testing the harness in that area,.....best off trying to repair/find the condition, as new underdash harness's are about $500,..........if your having Dash-instrumentlite issuses?,...9 out of 10 times it the dimmer switch, as the windings are exposed, and oxidizes over the years creating intermittent/high resistance surges,....new dimmer switches are avaliable for around $100+ ![](/ubbthreads/images/graemlins/Twocents.gif) .....and check and clean all grounds, even if you have to fabricate some grounds, it can't hurt, only help,....check your steering column under the dash, it should have a grounding wire/bayonet on the column mounting studs grounding the column, I usually like to fabricate a ground(s) for the instrument fascia panel,...the bulkhead fitting that you reference behind the battery, is the "lights forward harness" connector, all your front lites/directionals........ IIRC there's 6 wires in the harness, 1 is a ground....it helps to download a wiring harness manual for your car, or access a factory service manual, makes troubleshooting much easier, also make sure your floor mounted headlite high beam dimmer switch is in good condition and mounted to clean bare steel/clean screws, it needs a good ground, if the switch has seen better days replace it, they're cheap Mike
[Re: DAYCLONA]
#591173
01/23/10 05:28 PM
01/23/10 05:28 PM
pinkduster
Near Reading PA USA
I checked several websites... Jack's, BE&A, Dante's and Year One. Year One is the only place that advertise the turn signal switches. FD47801 is listed at $119... Not $52. (There is some inflation for 'ya.) ![](/ubbthreads/images/graemlins/down.gif)
[Re: pinkduster]
#591174
01/23/10 05:41 PM
01/23/10 05:41 PM
Posts: 18,160 Mass
DAYCLONA
Mass
WOW!....they've gone up since I've bought one! big time,...I know the 70 switch was more then,...I don't want to know how much now!.....could be Chryslers recent gougeing of prices, or limited stock that's doubling the price
