Re: tail light housing sealer
[Re: car48nut]
#591121
01/23/10 12:32 AM
01/23/10 12:32 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
They may have been taken off years ago. They did come from the factory with gaskets. Remember, your car is 41 years old. A lot can go on in that much time.
If you ever took any originals apart, you would see remnants of a hardened sealer... No gaskets. What documentation do you have that calls for gaskets? A gasket would make the joint too big.
[Re: RoadRunnerJD]
#591122
01/23/10 07:26 AM
01/23/10 07:26 AM
Posts: 12,439 Warren, MI
71TA
Warren, MI
Some 69's DID have gaskets. Majority used some kind of black seam sealer. No 70's had gaskets.
[Re: a4runer]
#591125
01/23/10 12:17 PM
01/23/10 12:17 PM
RoadRunnerJD
Warrenton, VA
Thanks all for the help. I know this is the place to come when the brain fade takes over. I know I have seen them with gaskets but this car had never been apart so I did not think gaskets were the answer.RoadRunnerjd post some pictures if you can.I painted mine alittle more silver then a4 when I did this used the same silver as on the new Mopars...Challengers,Jeeps and 300's.Really pops in the sun. Also has A4/pewter interior from the factory so aliitle different then most...I hope. Again Thanks to all...Bruce [/quote If you use a gasket, there's no place fir the water to drain out of the fender extension. Click on my signature link below for some photos. It's A4/B7 bright blue bucket seat interior
[Re: a4runer]
#591127
01/25/10 01:45 PM
01/25/10 01:45 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
The original caulk is white and there aren't any gaskets on 69 road runners. 3m Fast and firm works great. It seals and holds the paint for years and years. Put it on, assemble , wipe the excess off with your finger, let harden and paint as usual.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
