Re: VIC 340 [Re: S/ST 3040] #590861
01/23/10 03:38 AM
01/23/10 03:38 AM
IL
knyech1 Offline
knyech1  Offline
IL
Huh?
You're joking right.....
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: VIC 340 [Re: S/ST 3040] #590862
01/23/10 11:53 AM
01/23/10 11:53 AM
Az
Crizila Offline
Crizila  Offline
Az
So Vic, how thick of a spacer are you going to run with that thermoquad?...........
Huh?
Interesting combo you are flowing there. 915 casting heads? Got a lot of stuff stuffed between the manifold and carb - open / 4 hole?? Duz the small pri / big sec cause any flow change between runners - verses a square bore carb?
Fastest 300
Re: VIC 340 [Re: Crizila] #590863
01/23/10 01:28 PM
01/23/10 01:28 PM
On the south side of Nowhere
S/ST 3040 Offline OP
That's a 596 head, ported Victor 340, 2" adaptor and a 1 3/8" primary Thermoquad.
Some old preliminary flow testing for reference.
Some things are eye opening, most are disheartening but, you have to keep digging.
I wish I had a dyno.
