AVS help #590766
01/22/10 01:54 PM
01/22/10 01:54 PM
morrisville, pa
skajm Offline OP
skajm  Offline OP
morrisville, pa
Hi All,
Decided to try bushing my throttle shaft on the AVS. Throttle shaft is 3/8s found brass tubing 11/32. How can I shrink the brass down to be tight on the shaft?
Joe
Re: AVS help [Re: skajm] #590767
01/22/10 04:48 PM
01/22/10 04:48 PM
It cant be done, must get the right ID material
Re: AVS help [Re: RapidRobert] #590768
01/22/10 04:53 PM
01/22/10 04:53 PM
scratchnfotraction Offline
cant be done like that
call a carb shop for correct bushings
