Re: HELP1..I need a switch to turn on/off overdrive
[Re: stumpy]
#590349
01/21/10 07:25 PM
01/21/10 07:25 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
They have line lock switches that are not momentary switches?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: GLR]
#590351
01/21/10 07:26 PM
01/21/10 07:26 PM
Posts: 67 Florida
T-Man
There are some push button micro switches that will work great. I'm sure Mc Master Car or others will have them.
If you need to you can use a relay if necessary.
I agree with your customer it is great to have it in the shifter.
Good luck
gary
67 plymouth satellite
72 plymouth roadrunner
[Re: GLR]
#590355
01/21/10 07:46 PM
01/21/10 07:46 PM
Posts: 67 Florida
T-Man
You can find the right micro switch and completely hide it in the shift handle. Plus I rigged an LED so when it was in overdrive it lit up.
It was nice to know, however that was a stick.
If he is going to have overdrive in "D" then a light would be nice. If you want to get fancy hide and mount the switch so when he pushes the shifter button it goes into overdrive, Then mount a very small green led in the instrument panel and use a panel light power take off so it dims with the instrument panel lights.
It would take just a little extra effort but he'd be a happy camper.
[Re: GLR]
#590358
01/21/10 07:55 PM
01/21/10 07:55 PM
Posts: 7,759 So Cal
HealthServices
So Cal
You will have to research this unless someone else knows but I believe the housing can be taken apart. Inside if I remember correctly is a typical micro switch. You can replace the momentary switch with a on off switch if available from a electrical supply co.
Allen
