Re: STOP on a dime? NOT!
#58995
05/18/08 08:30 PM
05/18/08 08:30 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
See if you can borrow one of those "phoenix injectors" that reverse bleeds the system, basically pushes the air back to the MC from the bleeder screw. I have a tech friend who swears by it. Worth a shot.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
[Re: bschargerse]
#58996
05/18/08 08:39 PM
05/18/08 08:39 PM
never heard of those. i'll ask when i go get the vac. bleeder.
#58997
05/18/08 11:13 PM
05/18/08 11:13 PM
quick77rt
Parts Problem
Parts Problem
porportioning valve problem, I never thought they could go bad, dont know whats in them, check valves, or balls but they do go bad and sounds like this could be one of them... remember when you compress the calips your pushing fluid back when its supposed to be going the other way????? Let us know please....
[Re: quick77rt ]
#58998
05/18/08 11:28 PM
05/18/08 11:28 PM
replace BOTH p-valves. notta i keep the m/c cap of when i push the pistons back. but i'll tell yah.. so far i'm lookin' like a clown in my customers eyes.
[Re: p d'ro]
#59000
05/20/08 04:27 PM
05/20/08 04:27 PM
Posts: 4,558 Montana
FuryUs
Montana
So what happened today????? Gotta know... What else would cause the pedal not to come back up? I have heard of an internal break in the rubber line acting like a one way valve, so the pedal will not come back after it is pushed... I would replace the rubber lines. They are probably old as hell...
It's a '97 Neon--hell's way older than that. The collpsed line wouldn't allow the pedal to the floor if everything else was good.
[Re: HealthServices]
#59003
05/20/08 06:29 PM
05/20/08 06:29 PM
Posts: 2,568 God's Country Maryland
GODSCOUNTRY340
I've found this problem on two Neons, a '96 & '98. Remove both rear drums and make sure the shoes are still attached to the steel mount. They're just glued and do come off. Both cars had very low pedal and the owners couldn't figure it out. The shoes actually came loose and were at the bottom of the drum so when adjusting them you could feel drag but since there was no shoe left at the top, when brakes were applied the wheel cylinders would travel all the way out but push on nothing, causing low or no pedal.
Re: STOP on a dime? NOT! (UPDATE)
[Re: GODSCOUNTRY340]
#59004
05/20/08 09:50 PM
05/20/08 09:50 PM
found the problem. my helper wasn't following my orders on when to pump the brakes and when to hold them. suffice to say.. he's no longer my helper. thanks for all your reply's guys
#59006
05/20/08 10:47 PM
05/20/08 10:47 PM
yah, i did it myself. jar filled with brake fluid and a hose from the bleeder to the jar. i didn't charge her for all the extra stuff, wasn't her fault.. so i ate it. she was very happy
[Re: RodStRace]
#59009
05/21/08 08:31 AM
05/21/08 08:31 AM
mabey it was me.. who knows..
[Re: quick77rt ]
#59012
05/21/08 02:16 PM
05/21/08 02:16 PM
Posts: 4,964 Tri-Cities, Washington
VITC_GTX
Man thats crazy, my girl cant boil water, but she helped bleed the brakes in my van, if you scream loud enough most will listen.
Now that's funny...and true!!
[Re: VITC_GTX]
#59013
05/21/08 10:00 PM
05/21/08 10:00 PM
very funny
that kid has been retardo since day one. this was just the last straw.
