Re: megablock cam bearing issue
[Re: 602heavy]
#588839
01/20/10 06:59 PM
01/20/10 06:59 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Seems #2 cam bearing is a 'loose' fit in journal ,had to tap it in but could feel it was on the loose side , the old bearing was pretty easy to remove also , had no problems with the bearing spinning , thinking maybe intall with some locktight?
Green stuff works good also. I had #3 turn on me. The new bearing hammer in tight but I used the "goop" on the back just in case.
[Re: 602heavy]
#588841
01/20/10 07:47 PM
01/20/10 07:47 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Thanks , what's sleeve retainer? , can i get this in UK? [/quote
Permatex makes sleeve and retainer seal as does out manufactures. You can find it at most auto parts,machine shops or heavy equipment repair shops.
[Re: Jeremiah]
#588843
01/20/10 10:45 PM
01/20/10 10:45 PM
Posts: 1,200 UK
602heavy
UK
You should be able to get it anywhere in the world. If not, PM me and I will sent you some.
This is the stuff I have used a few times:
http://eastcoastgearsupply.com/i-129994-loctite-sleeve-retainer.html
Thanks Jeremiah , will see if i can get some here , did'nt realise it was a locktight product.
