MP 360 short block-intake not fitting. #588681
01/20/10 04:00 PM
01/20/10 04:00 PM
Sandy, OR
DART67GT Offline OP
DART67GT  Offline OP
Sandy, OR
I have MP block assembly p4876908 with eddy heads and air gap intake. The intake is not lining up with the bolt holes because the deck was shaved. The MP tech line said they couldn't tell me how much it was shaved because it was an older Cummins reman block and they no longer do business with them. I need to know so I can have the intake milled down to fit. Anyone know how much they took off these blocks?
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: MP 360 short block-intake not fitting. [Re: DART67GT] #588682
01/20/10 04:17 PM
01/20/10 04:17 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
It could be any amount decked off that they thought it needed.The one I had fit perfect with no gaskets,so I measured the gaskets I wanted to use,at .030- what I thought I needed for gasket compression.I had .027 cut from each side for a perfect fit.
According to the M.P.crate engine book,they were supposed to be set at a certain deck height,but the "908" shortblock I had(also from Cummins)had such terrible machining elsewhere,that I would not trust what it was "supposed" to be.
Re: MP 360 short block-intake not fitting. [Re: DART67GT] #588683
01/20/10 04:20 PM
01/20/10 04:20 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
After you determine how much the intake needs to be lowered to match
the bolt holes in the heads, multiply that number by .900 or the tangent
of 42º
So, if you need the manifold lowered .060":
.060 x .900 = .054" per side.
Make sure you use a gasket for initial measurement.
Re: MP 360 short block-intake not fitting. [Re: DART67GT] #588684
01/20/10 06:43 PM
01/20/10 06:43 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
Wouldn't it be better to have the intake side of the head shaved instead of the intake? That way if you wanted to try different intake manifolds you wouldn't have to have the intake manifold shaved every time. Just something to think about
Re: MP 360 short block-intake not fitting. [Re: 360DOUG] #588685
01/20/10 11:19 PM
01/20/10 11:19 PM
Sandy, OR
DART67GT Offline OP
DART67GT  Offline OP
Sandy, OR
I thought about that, but if I ever use these heads on a different block, I would run into the problem of having to get the deck height just right. Plus the heads and valve train are already installed. I'm hoping not to ever have to change either though. This is a mostly street driven car, so I won't be swapping intakes.
Re: MP 360 short block-intake not fitting. [Re: DART67GT] #588686
01/20/10 11:46 PM
01/20/10 11:46 PM
Sandy, OR
DART67GT Offline OP
DART67GT  Offline OP
Sandy, OR
Another question. I know my pistons were .017 in the hole. With that number would I be able to calculate the deck height?
