Re: tore down top of engine needs heads off now....
[Re: ph23vo]
#588663
06/26/10 11:54 AM
06/26/10 11:54 AM
Posts: 75,139 A Banana Republic near you.
JohnRR
john not sure what you are trying to see but lmk dan
I wanted to see what the side of that carb looked like , special linkage and a thick base gasket because of the choke well .
[Re: ph23vo]
#588664
06/26/10 01:15 PM
06/26/10 01:15 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Engine looks great Dan. Nice Job. ![](/ubbthreads/images/graemlins/thumbs.gif) Joe
65 Barracuda 70 Challenger
Re: W23 RECALL WHEEL 69 fury VIP is home
[Re: ph23vo]
#588665
06/26/10 01:46 PM
06/26/10 01:46 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
any other W23 full size cars out there known?
You already know what happened to the one I had. ![](/ubbthreads/images/graemlins/spank.gif)
[Re: ph23vo]
#588666
06/26/10 01:52 PM
06/26/10 01:52 PM
rrunner
S.E. Florida, USA
yep..loose lugs and alum wheels dont mix
Don't know if the funky lugs had anything to do with the coming loose problem. Do you have the OEM lugs for the W23 wheels? I also have a few parts from the 35,000 mile Fury I parted not all that long ago. I know I have in cluster and a perfect set of A/C center vents. Would you want them before I toss them? Sure I will find more when I do more cleaning out.
[Re: ph23vo]
#588673
07/13/10 07:45 PM
07/13/10 07:45 PM
Posts: 349 Mid west
C_stripes
Mid west
I do believe that is the car I told you about, am I correct? From Utah? I wanted it pretty bad, just didn't have the funds at the time.
Maybe the one I told you about was a 70. I don't remember.
Re: recall wheels on!
[Re: ph23vo]
#588678
03/19/11 10:49 PM
03/19/11 10:49 PM
Posts: 778 Washougal,Wa
Dodge
Washougal,Wa
Very cool car!!! I'm a big fan of B7.
Stand behind your word
