Re: my 3.9 still sucks
[Re: FuryUs]
#58867
05/25/08 09:41 PM
05/25/08 09:41 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
IAC is clean and working. It was working before, and I cleaned all that stuff when I had the intake off. No coolant consumption. Lot's of frustration but no obvious problem.
[Re: dave571]
#58868
05/25/08 09:44 PM
05/25/08 09:44 PM
plugged cat?
[Re: dave571]
#58870
05/25/08 10:07 PM
05/25/08 10:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm thinking the new timing chain was installed off a tooth.
I hope you didn't use the line up the dots method becuase sometimes those dots are misstamped.
[Re: Supercuda]
#58871
05/25/08 11:38 PM
05/25/08 11:38 PM
dave571
I'd believe that if the new chain had made any change at all to the running of the engine, but it didn't.
It would be nothing short of miraculous to install a new chain, and have it run the same as the old one with 1" of slack, IF the chain was actually the cause of the initial fault.
But for arguments sake, I did use the line up the dot's method that the service manual says to use, so I supose it isn't dialled in, and could be off. I won't be taking it apart to dial it in anytime soon though.
[Re: dave571]
#58872
05/26/08 12:44 AM
05/26/08 12:44 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Sorry to hear that the problems continue.Are you getting any fault codes? Did you pull the intermediate shaft out of the engine and check the gear for wear? I read that the dist did not have any play but that doesn't mean the intermediate shaft is ok.If it is worn it could move the timing to the edge of the 5 degree window needed and the rough idle and poor performance would be exactly how it would run.There was a run of bad shafts back about 95-96.Haven't heard of the problem on 99's but nothing is written in stone.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#58873
05/26/08 06:43 AM
05/26/08 06:43 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
I did have a bad injector on mine, off idle missfire, on a heavier truck I can see stumble and hesitation. Also have you checked to see that the timing is advancing. Also I had not seen or heard of intermediate shaft gear wear outside of the bushing causing wear but it is worth looking at. Your symtoms are the same as those caused by a worn bushing which is why I sugested it earlier.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: dave571]
#58875
05/26/08 10:31 AM
05/26/08 10:31 AM
Supercuda
About to go away
About to go away
up yours
Nothing miraculous about it, just bad luck. 1" of slack retards the cam timing, installing the new timing set a tooth off, or mismarked, will do one of two things to cam timing, retard it or advance it. So you got a 50/50 chance there.
It's a possibility to keep in mind that's all, especially if you used a low cost parts store replacement. Heck I had a new Cloyes setup start with slack in the chain, so back it went. I prefer Edelbrock's sets myself.
[Re: Supercuda]
#58876
05/26/08 10:34 AM
05/26/08 10:34 AM
Supercuda
About to go away
About to go away
up yours
Hmm, I though of something, lol.
You right compression isn't even side to side and is out of spec from high to low. Did you do a wet and dry compression test and you HAVE TO do it warm. Cause I think maybe your slacked timing chain may have allow a couple of valves to whack pistons. I know when the nyon let's go on OEM timing sets a 318 will bend all it's pushrods whack pistons with valves.
[Re: Supercuda]
#58877
05/26/08 11:35 AM
05/26/08 11:35 AM
Posts: 5,117 Haslett, MI
7DRRunner
Haslett, MI
I have the 3.9L in my DD and had a problem with injectors
never threw a code, and I ck'ed everything that has been mentioned so far in this thread
and of course, it only did this on occassion so it was tough to track down
one injector went bad and would actually leak a slight amount of fuel down in the cylinder
only after I parked it
so when I started it up, it smelled flooded, and ran like I had some huge racing cam in it
I could rev it for a minute to "clear" things out, but man - I had stumbling and hesitation like you wouldn't believe ...
hope this helps some .....
"Good luck on your project."
1970 Road Runner
"Accellertii Incredibus"
[Re: Scottmon]
#58880
05/28/08 02:21 AM
05/28/08 02:21 AM
dave571
I don't think it's a bent valve. Simply because I've never seen a bent valve that had any compression at all. Quote:
Most important first step: Have you checked for codes?
Yes, that was my first step, and no codes are present.
temp sensor is reading/operating normally on the pid data. Warms up as the engine does.
It is OBDII. No misfire data present.
I had the injectors out last night, and attemped to observe the spray pattern.
I'm not sure if I'm any wiser after that...LOL
They all squirt. Some do seem to 'mist' more than others, but none dribble. New ones are 35 bucks a piece. I'm not sure If I'm ready to make that leap on a guess. At least not yet.
I think someone areound here does that clean and test thing too. I'll look into it.
Thanks for the continued interest, and feedback on this issue guys
[Re: R70RUNNER]
#58883
05/28/08 09:06 AM
05/28/08 09:06 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
It is SMPI. Probably a bad computer. Get a "good" one from KRC or somewhere. I replace them all the time with the aftermarket performance ones as they are usually cheaper. Even the Mopar Performance ones are cheaper but I don't think they have them for a V6 but check and see.
[Re: HotRodDave]
#58884
05/28/08 11:28 PM
05/28/08 11:28 PM
dave571
Well, it still sucks, but some progress. Found it would run almost the same with 4 of the 6 injectors disconnected(lead me to believe they must be leaking down) I work at a ford store, so I was able to procure some new 4.6 injectors and install them. Huge improvement, but still sucks. Went for a a long drive this eve. MIL/Engine light came on near the last 1/4 of it. I'm hoping there's a code that will lead me to something.(can't check tonight, scanner is at work) I'll keep you up to date
[Re: dave571]
#58885
05/29/08 10:56 AM
05/29/08 10:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
turn the key on/off 4(?) times and it'll flash the codes...
