SB oil pan ? #588353
01/20/10 11:30 AM
01/20/10 11:30 AM
Ma
Voluster Offline OP
Voluster  Offline OP
Ma
Anyone using a Stefs aluminum pan or whatnot?
I'm putting together a stroker 340 base motor I'm digging the Aluminum pan
Just wondering if anyone has used them and seen issues
Anyone have pics of one?
thanks
Phil
Re: SB oil pan ? [Re: Voluster] #588354
01/20/10 05:47 PM
01/20/10 05:47 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
I have a Stef's pan, has the bump out on the passenger side. Can't remember the part number. You might have a few issues with headers that swing back towards the pan. It is 9" deep. Here are a few pictures.
Bill
1970 Charger R/T 1970 Dart Swinger 340/4spd
Re: SB oil pan ? [Re: Bill_G] #588355
01/20/10 05:48 PM
01/20/10 05:48 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
Another
Re: SB oil pan ? [Re: Bill_G] #588356
01/20/10 10:41 PM
01/20/10 10:41 PM
Ma
Voluster Offline OP
Voluster  Offline OP
Ma
Thanks for the pics but I don't think that will fit my chassis
Charles looks like the only other option
Re: SB oil pan ? [Re: Bill_G] #588357
01/20/10 11:33 PM
01/20/10 11:33 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'd be intrested in the part number, if you run across it.
Re: SB oil pan ? [Re: S/ST 3040] #588358
01/21/10 03:06 AM
01/21/10 03:06 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I have a Stef's in my A body. It is flat in front for about 4" before the tank (center tank)& has no kick out. It is baffled with a trap door and has a built in teflon coated windage screen. The only number I have written down for it is #639700803. I can't take a picture of it now, my car is not here. I am looking for a pic I may have taken before it was installed. Mine fits fine with 1 7/8 W2 TTIS.
Re: SB oil pan ? [Re: b1dartsport] #588359
01/21/10 03:41 AM
01/21/10 03:41 AM
b1dartsport Offline
b1dartsport  Offline
I just found the Jegs part# 861-1071 $399.99
Re: SB oil pan ? [Re: b1dartsport] #588360
01/21/10 09:55 AM
01/21/10 09:55 AM
S/ST 3040 Offline
S/ST 3040  Offline
Thanks for checking but, I think I can use the rear sump.
I still need some clearance at the front so, I can't use a
full dragster pan. My Milodon SS pans are 11" deep. Too low.
Re: SB oil pan ? [Re: S/ST 3040] #588361
01/21/10 12:35 PM
01/21/10 12:35 PM
Maryland
Bill_G Offline
Bill_G  Offline
Maryland
Could not find my files with the PN, after looking at the Stef's site without pictures, my best guess is it is a 1675 comp eliminator pan, it has the kick out, teflon screen, and came with an Stef's pickup, the measurements are not quite the same as the catalog, but mine is 9" in the rear and 5" in the front. Hope it helps!
Bill
Re: SB oil pan ? [Re: Bill_G] #588362
01/21/10 01:02 PM
01/21/10 01:02 PM
S/ST 3040 Offline
S/ST 3040  Offline
Thanks Bill. I'll look into it.
