Re: Quest for the tens. One move at a time... [Re: Quicksilver440] #587754
01/20/10 01:16 AM
01/20/10 01:16 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
it has / or had something to do with Dynamic.
The Dynamic guy moved on? Or he took tct to dynamic? im not sure
not sure on the whole story--
sixpackgut may know
Re: Quest for the tens. One move at a time... [Re: 493_DART] #587755
01/20/10 02:04 AM
01/20/10 02:04 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
sixpackgut may know
Thanks...I searched for TCT and came up with links to "Dynamic racing transmissions"...but all the links are dead.
I'm running a Frank Lupo dynamic 9.5"...but it wasn't made for my combo (it's too tight). I've thought of having mine loosened up or having a new one built.
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587756
01/20/10 09:28 AM
01/20/10 09:28 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What's it run in the 1/8? If I were doing one thing it would be a good port job, then get a converter next year. I've had good luck with Edge Racing Converters, talk to Andre.
www.edgeracingconverters.com
Re: Quest for the tens. One move at a time... [Re: 1Bad440] #587757
01/20/10 03:25 PM
01/20/10 03:25 PM
South Carolina, United States
carolinacuda Offline OP
Im not sure bout weight. But I got a Glass hood with and alum radiator. I also removed power steering to save some weight. Im thinking bout 3500ish maybe. Thanks for all the responses. The compr is 10.8 and the stall is a 10". My 1/8 is 7.32 @ 90mph (i think) not positive, im not at home and time slip is there. My fuel line is 3/8
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587758
01/20/10 03:57 PM
01/20/10 03:57 PM
K
Kiddart Offline
Kiddart  Offline
K
you can try this I know other converter companise do this. let them know you purchased the converter thru them and its to tight, have them loosen it up a bunch thell them the specs get a price and weigh the cost of a new verse getting this one worked. then you may have enough left over to put some money into the heads or a gear swap. I suggest you run at least a 4.10 to 4.30. look on here for the parts most of the guys on here are truely honest about what they are selling. and if you need to ask about someone selling parts feel free. you will also find they guys on here are generally a very tight nit group. thats my
Thank you
Kiddart
Re: Quest for the tens. One move at a time... [Re: Kiddart] #587759
01/20/10 04:44 PM
01/20/10 04:44 PM
gregsdart Offline
gregsdart  Offline
Finding out what it wants for a tuneup would be first in my book. If there is a very good chassis dyno and operater in the area, I would go there. Also, stuff like long collecters, cold air package, unstable timing, timing curve, cam installed centerline (maybe advance it?) and a bowl port and sharp valve job on the heads ( > $350? )to get the most out of it. If you have done the heads, great.
Try less lash, first on intake then exhaus. Watch the individual segments of the run, plus weather, to get accurate data.
Finally, the dyno will show if you need some jet changes, and if the air fuel ratio is right at all rpm ranges.
Re: Quest for the tens. One move at a time... [Re: gregsdart] #587760
01/20/10 04:59 PM
01/20/10 04:59 PM
indiana
moparbrown14 Offline
indiana
good luck asking a question like that cause you are going to get a thousand different answers. good luck on picking which one is right for you
Re: Quest for the tens. One move at a time... [Re: moparbrown14] #587761
01/20/10 05:10 PM
01/20/10 05:10 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I remember this well...I was chasing 10's along with Gary (UNLAWFL) in 2003...my big help was ATI 8" convert. and Cal Tracs with 4.10 I went from 1.58 60' to 1.45 best w/slicks. Call Cal tracs and get there 90/10 shocks ....and rancho 9way for rear ...my 2
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587762
01/20/10 05:30 PM
01/20/10 05:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
11.49 @118mph with a 1.55 60ft.
I see a bunch of people screaming for a converter. However, unless you've run the #s to calc your slippage percent w/ the current one and know it's 10% or more, I don't think you're going to see much from a converter change, assuming you stick w/ a street/strip converter.
How much RPM is it turning going through the traps at 118 MPH? IIRC, when I used 4.10s w/ the same size tire mine were around 6300 at that MPH and my converter slippage was 7-8%. It would have been around 6000 for me w/ 3.91s.
What model of 850 Demon? Have you actually done any tuning on it at the track to see how the car responds to jet changes, etc.? "Out of the box" jetting for some Demon models are pretty far from ideal, to be blunt.
How's the ignition set up? Done any comparisons of different total timing #s at the track?
What's the rest of the exhaust behind the headers? Are you running mufflers that are choking it down, even w/ a 3" setup?
I don't particularly think stock EZs w/ a standard port size are that effective for a combination like yours (it's a big volume for that flow level). There might be some gains from having somebody who knows those heads well do some work to make them "happier". (Suggestion: Dwayne Porter at Porter Racing Heads in Vermont)
Do you have enough valve spring to let that engine rev to 6600-6800 rpm w/ that cam? If you really pick up some MPH from porting or whatever, it's going to want to spin that high.
These are all improvements that can be found from "super tuning" and lots of test & tune time at the track. However, as it stands you simply don't have the MPH to break into the 10s, if you intend to keep it a legit street car. I just barely broke into the 10.9s w/ a 1.53 60-ft. and my MPH was 122+. The 1/8th mile time was in the 6.9s at 98 MPH.
Been there, done that, got the credit card bills and the stack of time slips to prove it.
Re: Quest for the tens. One move at a time... [Re: BradH] #587763
01/20/10 07:53 PM
01/20/10 07:53 PM
Thanks for your guys. The 850 demon is out of box. Timing is at 36. 3" exhaust with flowmasters super 40's turned down at axle. I have wondered bout the springs though. Im using the Indy springs that came on the heads. (supp to be good for .600 lift). Im at about 6200 rpm when crossing the stripe. I do have a set of 4.56's that i got a good deal on. Thaught bout using them but man thats low for a street car. Plus I feel they will put the rpm's too high at the line. Not sure if stock bottom end can handle that kind of R's for long. I agree that i need a chassis dyno to see what works or doesnt. Just dont know of one around here.
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587764
01/24/10 11:07 PM
01/24/10 11:07 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Converter needs to go for sure.
I had a TCI 10 inch that at the time performed OK. But looking back it had about 13 percent slip, which sucks, plain and simple.
In my car a TA tight 8 inch that flashes right under 5k was worth at least .17 over a very decent PTC that flashed at 4200. Both converters calculate to 8 percent slip.
Id bet you would pick up .2 and 2 MPH with a better converter.
As others have said there should be more in your combo, maybe 10s as it sits. 10s with a converter change and tuning.
I didnt read the whole thread, but did you have the seats reground on your heads or are they the Indy supplied valve job?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Quest for the tens. One move at a time... [Re: carolinacuda] #587765
01/25/10 10:54 AM
01/25/10 10:54 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I have to go with the converter here.I run a SB in my 3420# Aspen and i have a TCS 8" that flashes at 5400.Back in the summer my ET/60' times were all over the place and i was told the converter is on it's way out.I was also told TCS was no longer in business and bought a Ultimate 8",shortly after i found TCS again alive and kicking and sent my converter back and they replaced the sprag.I wanted to try the Ultimate before anything else from everything i've heard about them.The Ultimate was waaay too tight and slowed my 60' from 1.47-1.66 and the ET went from 11.0 -11.9 so 3 passes is all i made.Put my TCS back in and my 60' was back to a new best of 1.41 and ET best of 10.76.Oh and i run with stock leafs with 1 extra leaf each side and pinion snubber as well.I'd like to try Cal Tracs but don't think i'd see any improvements and no one makes 90/10's for F-body cars.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
