Re: Big Block Valve Covers
[Re: msanchi]
#587676
01/19/10 04:14 PM
01/19/10 04:14 PM
RapidRobert
Maybe a good drop of blue loctite on the threads would keep em tight
[Re: msanchi]
#587677
01/19/10 04:14 PM
01/19/10 04:14 PM
Ive had good luck with the cork/rubber gasket and have used Indian Head gasket compound on both sides of the gasket without any leaks. I also put some med. strength loktite on the bolts to keep them from backing out. Tighten them down snug with a 1/4" drive nut driver or lightly torque them down with a 1/4" rachet.
[Re: ]
#587678
01/19/10 04:23 PM
01/19/10 04:23 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I like to use the Fel-Pro cork/rubber, CLEAN HEAD and I spray glue the gasket to the head with 3M SUPER77 spray glue, heavy coat, I spray glue the gaskets to the head so that I can remove the covers for valve adjustments, and not worry about the gasket after it has "cycled" in size due to heat, slipping under the cover, causeing a leak when I remove the cover, never had a leak in over 5 yrs, tighten the bolts hand tight, do not overtighten
[Re: DaytonaTurbo]
#587683
01/19/10 06:48 PM
01/19/10 06:48 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
My M/T's are leaking like crazy. I had those high dollar Moroso's and the M/T's cut them for what ever reason. So I went those hard black ones from Fel-pro and they are leaking now. 915 BB heads.
Moparlee
[Re: Stanton]
#587687
01/19/10 09:22 PM
01/19/10 09:22 PM
Posts: 15,487 Florida
scratchnfotraction
I used the thick black felpros with stock VC I glued the gasket with copper rtv and then put a thin bead on the head side I used some sb VC bolts with the triangle pull downs I had to crank on them kinda hard then finaly felt them crush a little let it cure over nigh..no leaks so far i tried them before on a sb and they leaked...but I was ![](/ubbthreads/images/graemlins/runaway.gif) to crank down on them and swaped them for cork then was told you have to "feel" for it to crush some and they will seal dry.. ![](/ubbthreads/images/graemlins/shruggy.gif) result will vary ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: DaytonaTurbo]
#587689
01/20/10 11:35 AM
01/20/10 11:35 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I run the hard/thick felpro valve cover gaskets. I ran a good thick bead of rtv along my valve cover flange, plaged the gasket on the table and put the valve cover on top so the rtv could dry the gasket to the cover while being on a flat surface. Seems to have worked pretty good so far. I could rtv both sides of the gasket, but that would make for one heck of a mess when it came time to pull a vc for whatever reason.
.....This is the ONLY way I can keep my aluminum covers on my race engine sealed up. I am using the orange gaskets from Mopar....NO MORE Moroso ones 'cause they split and leak along the headers . Silicone them to the covers and let them dry over night like said. ![](/ubbthreads/images/graemlins/thumbs.gif)
