Headers Vs. HP Manifolds #586676
01/18/10 05:52 PM
01/18/10 05:52 PM
California
P
Plymouth273 Offline OP
P
California
I am building a 66 Sport Fury 383-4 Automatic, 11.0:1 Compression, 484/284 Mopar Performance cam and I have been going back and forth on putting headers vs. HP Manifolds on the car. The C-Body headers are out there but they are expensive, is the added expense worth it for the headers? The car will be mainly a fun street car but also may hit the strip a few times.
Thanks.
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586677
01/18/10 05:57 PM
01/18/10 05:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How much are the cheapest headers for your car? I run the $100 summit headers on my car and they do just fine, however if no cheap option exists for your car I would go with some HP manifolds if you can get a decent deal on them.
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586678
01/18/10 06:01 PM
01/18/10 06:01 PM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I think you would like the performace of the headers better than the manifolds.
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586679
01/18/10 06:07 PM
01/18/10 06:07 PM
AndyF Offline
AndyF  Offline
Big block HP manifolds work just fine up to the 550 or 600 hp level. No problem running them on your setup.
There are some articles in the tech archives if you want to ready about dyno testing with HP manifolds.
Re: Headers Vs. HP Manifolds [Re: AndyF] #586680
01/18/10 06:09 PM
01/18/10 06:09 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i heard somewhere that b body headers fit c body's but you have to slide them in from the bottom
Re: Headers Vs. HP Manifolds [Re: 72d100] #586681
01/18/10 07:28 PM
01/18/10 07:28 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
with a full exhurst system on the car you'd never tell the difference in power. The headers may show a bit more on a dyno but not in the seat. You can only flow so much through any full system. Run the stock HP manifolds. They fit, they don't leak you'll never have to fool with them unlike any aftermarket from cheap summit headers through big dollar Hooker super comps. On a full on race car yes headers , uncorked will give a big power improvement. You can only force so much air through all that pipe and mufflers.
Re: Headers Vs. HP Manifolds [Re: AndyF] #586682
01/18/10 07:46 PM
01/18/10 07:46 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
The HP manifolds I have are -
RH 2899879 N4
LH 2951865-2 B7C
Made on dayshift 22nd October 1969
The testing I have done so far has proved the LH manifold is the better of the two
Runner #5 & #7 are close
#1 is the best flowing, but not a heap better than #5 & #7
#3 has 40% more restriction/back pressure than the others
The RH manifold is worse.
Runner #8 is the best of both sides, showing 1/2 the restriction/back pressure of #3
#4 is a bit better than #1, #5 & #7
while #2 is a bit worse than #1, #5 & #7
#6 is the worst of all & shows 120% more restriction/back pressure than #8
If I can get my flow issues sorted out I'm going all the way with anti-reversion at both joints (heads to manifolds & manifolds to headpipes), thermal barrier coatings on manifolds & headpipes etc
I'm running 2 1/2" pipes now but I have started to build a 3" to 2 1/2" antireversion fitting at the flange between the manifold & headpipe. As there is documentation that a 3" headpipe helps the HP manifolds work.
Re: Headers Vs. HP Manifolds [Re: nz383man] #586683
01/18/10 08:12 PM
01/18/10 08:12 PM
Long Island NY
yellow sixpack Offline
Long Island NY
I agree with Doug if your not racing go with the HP alot less hassles they flow really well and with the right mufflers they sound great.
If you can't be smart.....don't be stupid!
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586684
01/18/10 08:55 PM
01/18/10 08:55 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
you will always get more HP out of headers but are you willing to cough up the initial expense, live with unending leaks and having to remove them every time you need to replace the starter?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586685
01/18/10 09:33 PM
01/18/10 09:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It really is a personal choice based on what you want. However, it is my opinion that the MP484 cam is not a good choice with exhaust manifolds.
Re: Headers Vs. HP Manifolds [Re: RangerDan440] #586686
01/19/10 01:02 AM
01/19/10 01:02 AM
Manitoba, Canada
Manitoba, Canada
Hey I installed my stock 90's mopar ministarter WITH my cheapie summit headers already bolted to my 440! Wasn't fun but I did it.
Re: Headers Vs. HP Manifolds [Re: BSB67] #586687
01/19/10 10:13 AM
01/19/10 10:13 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I couldn't agree more. Night and day difference with the same cam in my cuda.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586688
01/19/10 10:20 AM
01/19/10 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well 1st I'll say this, that cam is not a "driver" cam. It is designed for bracket racing, It works with HEADERS, good intake, high stall and 3.91 gears. I had one in a mild 440, w/ logs and 3.55's and it was a complete dog.
As for the header question, yes they help alot but if you alrady have that cam in the car w/ no stall and less that 3.91 gears, it won't trelly matter if you have headers or not.
Coming soon!!!!
Re: Headers Vs. HP Manifolds [Re: Mr.Yuck] #586689
01/19/10 01:32 PM
01/19/10 01:32 PM
California
P
P
California
Thanks for the replies, the car does have a stall and 3.91 gears in it, the heads have are 906 with a little work, stock intake that has been mildly worked but I will upgrade if necessary in the future. If it makes a difference, the HP manifolds are 67 C-Body 440 HP's, not sure how well they breath compared to a B-Body HP.
Thanks, any info is appreciated.
Re: Headers Vs. HP Manifolds [Re: Plymouth273] #586690
01/19/10 06:28 PM
01/19/10 06:28 PM
Mid Michigan
Mid Michigan
If you have a good exhaust system (2.5 or better) and hi flow mufflers, I think you will notice a big difference with headers. With that cam, I think you can expect a fall off in power big time over 5k. I switched to headers on my car with a mild combo and it made a ton more power.
Re: Headers Vs. HP Manifolds [Re: Mr.Yuck] #586691
01/19/10 11:03 PM
01/19/10 11:03 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I think this cam expects higher compression than a stock deck 440 will have. This combo on a zero-deck engine with true 10.5:1 will have some bite.
Re: Headers Vs. HP Manifolds [Re: Vert] #586692
01/20/10 12:05 AM
01/20/10 12:05 AM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
look into shumaker headers. fit in my 440 duster with p/s great can't imagin a problem in your car. very good quality.
Re: Headers Vs. HP Manifolds [Re: AndyF] #586693
01/20/10 02:03 AM
01/20/10 02:03 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Seeing this from Andy makes me feel better about the 1-3/4" headers I'm using on my 451 build. (shooting for 525 hp.)
(sorry to hi-jack)
Re: Headers Vs. HP Manifolds [Re: StealthWedge67] #586694
01/20/10 09:38 AM
01/20/10 09:38 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a big C body with a small motor, you'll prefer a cam more like a lunati voodoo 60302 or 60303 than the MP484.
2017 Grand Cherokee Overland
Re: Headers Vs. HP Manifolds [Re: patrick] #586695
01/20/10 09:08 PM
01/20/10 09:08 PM
The Garden State
LimelightCuda Offline
The Garden State
A friend of mine who knows a lot more about racing than me said the same thing. He also said the MoPar HP manifolds are designed really well and are better than the Chevy or Ford version and he is a Chevy guy.
I am trying to make the same decision about headers vs. HP manifolds. I have headers right now and I love the sound and performance the car has. What I don't like is no power steering and the fact that the headers capture the starter. If I didn't go on long trips with the car I wouldn't care about that but I worry should the starter fail far from home. The car has a 440 with the MP474 cam in and it has high compression. I'm guessing at least 10:1.
I've had the headers for 4 years and have yet to have a leak but due to where the car was kept they have rusted badly. I guess I am lucky in the leak department. [knock on wood]
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
