Push Button Trans Question
#585678
01/17/10 04:44 PM
01/17/10 04:44 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
I have a guy who is selling what is supposed to be a big block 727 trans from a '65 Imperial. I was setting up to go out to look at it and most likely pick it up (I am out of state for a funeral, and he is about an hour and a half from the hotel I am staying at), and he just told me it isn't a slip yoke, but a fixed yoke trans (he was sure it was a slip yoke when I asked before I left, but he hadn't looked at it in a few months). I was planning on using this trans for my 440 swap in my '64 Polara. Any way I can still use this trans in my car? Will a late model 727 tailshaft and housing swap with this one? I'm kinda in a crunch for time since I am leaving tomorrow morning, and can't really research this myself, since I am out of town and don't have reliable internet access. (I am using the hotel's computer, since they have a malfunctioning access point in my room, and no WiFi to use my laptop) Thanks in advance for any info you can help me with.
Whenever I am online I am totally naked.
(Under my clothes)
Re: Push Button Trans Question
[Re: Cooter]
#585679
01/17/10 04:59 PM
01/17/10 04:59 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I know they can be changed over.I know the 65 has a rear pump but 66 dosent.Rocky
Chrysler Firepower
[Re: therocks]
#585680
01/17/10 05:01 PM
01/17/10 05:01 PM
Cooter
Chicagoland
So I could swap it out even though the later tailhousing came from trasn witout a rear pump?
(Under my clothes)
[Re: Cooter]
#585684
01/17/10 06:29 PM
01/17/10 06:29 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In '65 the Imperial was the only 727 that didn't change over to the slip yoke.
If your '64 Polara has a console shift the Imperial trans will work as is but if it's pushbutton the valve body is different. You can swap the valve body out of the original '64 SB trans into the '65 or you can use the '65 valve body with your pushbuttons but you'll have to use the '65 cable adjustment procedure, not the '64 procedure.
