ThermoQuad surging issue - ideas? #58510
05/14/08 03:59 PM
05/14/08 03:59 PM
OHIO
K
Krucial_Engineer Offline OP
K
OHIO
All
I had a TQ built for my 360, .030 over, 8.5-1, nice lumpy purple shaft cam (specs unknown) TTI headers, M1 dual plane intake. Previously, I had an LD4B intake and an Eddy 600 on it, which ran and idled fine, just a bit rich though. Carb needed a rebuild so I had Demon Sizzler build a TQ and swapped on the M1 intake.
At idle, the carb seems to surge and vary around 300 rpm. I'm seeing the same surge and possibly a light miss at low rpm speeds. When the 2ndaries kick in, it pulls real hard. I'm hearing a whining audible noise from the carb at idle, not sure if that is normal or not. I haven't changed timing, so I am looking for ideas as to what the problem is: vacuum leak? TQ primaries too lean?
Re: ThermoQuad surging issue - ideas? [Re: Krucial_Engineer] #58511
05/14/08 04:21 PM
05/14/08 04:21 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Have you PM'ed Demonsizzler with your questions?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: ThermoQuad surging issue - ideas? [Re: HemiRick] #58512
05/14/08 09:12 PM
05/14/08 09:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I couldn`t get my 340 with a stock thermoquad to idle well with a purple shaft cam. Not knowing how to fix it I put a stock cam back in and my problems were over. I do miss the lumpy sound though. Mike
Re: ThermoQuad surging issue - ideas? [Re: HemiRick] #58513
05/14/08 09:46 PM
05/14/08 09:46 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Could the whine be a whistle caused by a vacuum leak? Make sure your throttle shaft bushings aren't shot.
With a lumpy cam you will probably want to drill a 1/16" to 1/8" hole in each primary throttle blade to get a better idle. This way you don't have to turn the idle speed screw in too far and bypass the idle circuit.
I run a chokeless 850cfm TQ on my 340 with a MP508 cam, RPM manifold & headers. I have 3/32" holes drilled in mine and my idle mix screws are 3 turns out. My jets are 96 primary with 147 secondary and 63/50/40 metering rods. Squirters are drilled out to .032 and metering tree height is 1-1/4 turns.
I love the way the TQ looks and runs on my car.
4428173-dusterdigitalpic (183 downloads)
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: ThermoQuad surging issue - ideas? [Re: MY340] #58514
05/14/08 09:49 PM
05/14/08 09:49 PM
there's a screw on the metering rod tree you can adjust to compensate for larger cams.
if you run outta adjustment on that, you can use a weaker spring that the tree rides on.
no need to drill holes just yet.
Re: ThermoQuad surging issue - ideas? #58515
05/15/08 06:22 AM
05/15/08 06:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
IF, after you CHECK EVERYTHING for vacuum leaks and find none, AND IF you're running a larger than stock cam, and adjusting the metering rod tree doesn't help with surge or idle. Here are a couple items that will fix the problem. First on idle.
Take a numbered set of drill bits and using them as a gauge find the size that fits EXACTLY in the small brass tube in the picture. Drill it .001 to .003 larger. That should do wonders for a thermoquad that won't idle with a larger cam,(richens idle).
IF you have an LM-1 meter the next mod will help you really dial in the lowspeed curcuit.
Pick up some holley bleed blanks and drill and tap lowspeed bleeds. FIRST though use numbered drill set to find out the stock bleed sizes and WRITE them down for reference.
To richen the curcuit up go a couple thousandths SMALLER on the bleed. For the hispeed primary bleed you can also do the same. Hispeed bleed is the other bleed shown in the picture. Dave
After rereading the post and seeing that Demonsizzler did the carb for you, I'd talk to him before doing ANYTHING to your carb. He is the master at modifying thermoquads.
For you other guys that feel adventurous, these mods can be done at home by anyone with a little mechanical ability. I WOULD NOT screw with a numbers matching carb but find another replacement to modify. You don't need to drill holes in the butterflys to get one to idle.
Re: ThermoQuad surging issue - ideas? [Re: quickd100] #58516
05/15/08 07:14 AM
05/15/08 07:14 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Definately call DS first.
Thanks for the big pics and tech QuickD!
Please keep us updated on your carb tuning.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: ThermoQuad surging issue - ideas? #58517
05/15/08 08:21 AM
05/15/08 08:21 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
The screw on the metering rod try adjusts how far the rods enter the primary jets under full vacuum. Drop it and you lean out the cruise mixture, raise it and it will richen cruise.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: ThermoQuad surging issue - ideas? [Re: CJK440] #58518
05/15/08 08:29 AM
05/15/08 08:29 AM
OOPS! idling surge.. missed that part
do what quickD100 said then.
Re: ThermoQuad surging issue - ideas? #58519
05/15/08 09:17 AM
05/15/08 09:17 AM
OHIO
K
K
OHIO
Thanks all
Those pictures are worth a thousand words!
I've contacted DemonSizzler about it.
Re: ThermoQuad surging issue - ideas? [Re: Krucial_Engineer] #58520
06/04/08 04:43 PM
06/04/08 04:43 PM
Citrus Heights, CA
69_Swinger Offline
69_Swinger  Offline
Citrus Heights, CA
FYI, I have also read that floats being set too high will result in surging idle as well as gas seeping between the bowl and cover.
67 Valiant /6 2-door (Father/Daughter project)
