Page 2 of 4 1 2 3 4
Re: F.A.S.T. Hemi dyno results/video [Re: dirtybee] #584372
01/17/10 12:36 AM
01/17/10 12:36 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
When you told me how much torque the engine made I thought you were confused...Now i'm the one confused
Re: F.A.S.T. Hemi dyno results/video [Re: scatpacktom] #584373
01/17/10 01:46 AM
01/17/10 01:46 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
when i looked at my dyno sheets my torque was low too.. Cam ? Manifold ? Whatever it is seems to work for him .
Re: F.A.S.T. Hemi dyno results/video [Re: sogtx] #584374
01/17/10 09:31 AM
01/17/10 09:31 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Dave, I know you guys are limited by rules regarding oiling systems.
A lot of folks say that kind of rpm's is a no-no with an internal pickup system. I notice no external pickups.....is there anything special you do to the oiling system to make it live?
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: F.A.S.T. Hemi dyno results/video [Re: Steve1118] #584375
01/17/10 09:45 AM
01/17/10 09:45 AM
N of Detroit
DaveDudek Offline OP
N of Detroit
For the last 3 years all i have ran is a stock oil pump (no hi-volume or pressure) and the stock pick-up. I didn`t notice it in the car but the oil pressure drops 5 lbs from 6000 to 7500 RPM.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584376
01/17/10 09:55 AM
01/17/10 09:55 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
very impressive sounding and it sure makes some power!!
Re: F.A.S.T. Hemi dyno results/video [Re: scatpacktom] #584377
01/17/10 09:58 AM
01/17/10 09:58 AM
N of Detroit
N of Detroit
Yea, after looking at actual dyno results it seems odd that a engine with all stock stuff (modified, of course but restrictive none the less) and 496 cubes made a low peak TQ number and close to 6000rpm to boot, carried 750HP from 7000 to 7500 RPM and never fell off. Cam is 248/256 on a 114.
I`ve been shifting at 7500, maybe it would go faster shifting higher yet??
Dave Dudek
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584378
01/17/10 10:09 AM
01/17/10 10:09 AM
Steve1118 Offline
Steve1118  Offline
"For the last 3 years all i have ran is a stock oil pump (no hi-volume or pressure) and the stock pick-up. I didn`t notice it in the car but the oil pressure drops 5 lbs from 6000 to 7500 RPM."
That's with the MP 6qut oil pan, correct? Any scarpers or any such animal? Has there been any sign of bearing issues when the motor is disassembled?
Just wondering. Thanks!!
Re: F.A.S.T. Hemi dyno results/video [Re: Steve1118] #584379
01/17/10 10:11 AM
01/17/10 10:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think Wow summed it up pretty well
Re: F.A.S.T. Hemi dyno results/video [Re: Steve1118] #584380
01/17/10 10:33 AM
01/17/10 10:33 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Steve,FWIW,
On an engine I built for FAST, he generally runs 6,800-7K through the traps. I have incorporated some oil mods,(scraper, unidirectional screen,"blueprinted" pump and a 3/8" pickup), stock pan but nothing exotic. I have never seen any bearing issues on teardowns.
MB
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584381
01/17/10 10:39 AM
01/17/10 10:39 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I guess that torque number kinda explains why the car launches and gets out as well as it does.
MB
Re: F.A.S.T. Hemi dyno results/video [Re: HPMike] #584382
01/17/10 10:46 AM
01/17/10 10:46 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Daves car knocked the mains out no too long ago. That can't be a good sign
Re: F.A.S.T. Hemi dyno results/video [Re: scatpacktom] #584383
01/17/10 12:36 PM
01/17/10 12:36 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Nice!
Good luck next year Dave!
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584384
01/17/10 01:20 PM
01/17/10 01:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
FWIW - in my car, because of the large rpm drop at shift recovery, especially between 1st and 2nd, the car is fastest shifting about 600 to 700 rpm over peak hp. I'm sure its a function of the power curve after peak, and the torque converter. Because of my unique converter choice, this would probably not apply to most cars. but I thought I'd pass it along.
Thanks for share all this info!
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584385
01/17/10 03:19 PM
01/17/10 03:19 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
OK, after 3 solid years of racing I finally pulled the Hemi out to be freshen up, with help from Jeff were gonna try to find a few more HP`s to keep the Mopars out in front yet another year..
I took the Hemi over to Modern Clyinder Head a couple days ago and today we fired her up to get some "before" results before we tear into her. After about 160 passes, 7500 shifts, 7700 through the traps, here`s what she did. We did not move the timing or jet the carbs as of yet. Click here to see dyno sheets: Dyno Sheets Click HERE!! 770HP
For video click picture below:
Just thought you guy`s might enjoy it...
That's inspirational! Thanks Dave!
Re: F.A.S.T. Hemi dyno results/video [Re: scatpacktom] #584386
01/17/10 04:09 PM
01/17/10 04:09 PM
detroit area
moderncylinder Offline
detroit area
actually the "car" didnt knock them out,, he runs a babbit main,, babbit bearings wont usually go 50 runs because they are soft,, he just left them in too long,, has nothing to do with oil pressure/aeration or anything other than # of cycles
Re: F.A.S.T. Hemi dyno results/video [Re: moderncylinder] #584387
01/17/10 04:16 PM
01/17/10 04:16 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Ahhh, I see.
Re: F.A.S.T. Hemi dyno results/video [Re: scatpacktom] #584388
01/17/10 06:39 PM
01/17/10 06:39 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Man I thought that was old school , No Clevite ?
Re: F.A.S.T. Hemi dyno results/video [Re: sogtx] #584389
01/17/10 08:47 PM
01/17/10 08:47 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Dave, what do you think your air filter setup would do to your AFR? Before you took it off the dyno, did you try leaning it out a little?
Re: F.A.S.T. Hemi dyno results/video [Re: VanishPt] #584390
01/17/10 09:10 PM
01/17/10 09:10 PM
N of Detroit
N of Detroit
We will be doing more dyno pulls, these were just the initial results pulled right from the RR. I`ll be stopping by Modern tomorrow.. We will be leaning out the carb a ton, moving valve lash and i`ll be waiting for a special package from Joel Nystrom. Were hoping for a for a nice HP increase once the package arrives, from there i`ll be leaning on Jeff heavily to find HP.. We (the Chrysler camp) will need everything we can get to stay near the top next year.
Dave Dudek
Re: F.A.S.T. Hemi dyno results/video [Re: DaveDudek] #584391
01/17/10 09:36 PM
01/17/10 09:36 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Wow!! Dave had to play that a few times.Good Luck keeping the Mopar Colors on Top!
Page 2 of 4 1 2 3 4
