Rear Brakes, No way to Push to release
#584316
01/16/10 04:02 PM
01/16/10 04:02 PM
Posts: 230 Long Island, New York
Tony H
I've done brake jobs for many years.
What's the deal with the 9" drums on this '70 'A' body? There are two slots to get the Brake spoon in yet the adjuster ends up directly between the two. Secondly I had to force the Drum off because there is no way to get anything in the slot and release the self adjust so you can spin the star to loosen the Shoes. Do you guy drill into the Drum so you can release the adjuster?
'75 CJ5 with all glass body and a 350 Chevy SB '85 Chevy Stepside (the wife's) '89 Volvo All 100% maintained by me. '70 valiant DD for my son '74 Dart Swinger..Latest endeavor http://home.lyse.net/brox/TonyPage4.html
Re: Rear Brakes, No way to Push to release
[Re: Tony H]
#584318
01/16/10 04:36 PM
01/16/10 04:36 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
I wouldn't drill the drum. I have a brake spoon with a slight offset on the end that I have used in tight access holes. I've had mine for years but I'm sure someone still sells them. I have also used a small screwdriver to push back on the plate to release the star wheel.
[Re: Reggie]
#584319
01/16/10 06:26 PM
01/16/10 06:26 PM
RapidRobert
Take a long thin cheap(cheap ones are easier to bend) screwdriver & bend it slightly at the right spot along it's length so it will go under the barrel of the adjuster & slightly up to contact/push back the flat piece then as said angle your spoon in from the other slot to lever the threads. The left (pass) side should have left hand threads and they are easy to spot w their wierd twist on the threads so w several seconds of visualizing you can figure which way to turn the star.
