727 slipping between 2nd & 3rd #583801
01/15/10 10:57 PM
01/15/10 10:57 PM
Macomb,MI
Bob's71R/T Offline OP
Macomb,MI
I know i'm going to have to pull the trans.. thats no big deal but do i have to replace the bands / clutches / etc..etc..my car is makeing appr. 450/500 hp.1st & 2nd rock but 3rd i know i'm losing lot's of pull.if you guy's and gal's could help me it would be appriciated..Thank's Moparts..
Re: 727 slipping between 2nd & 3rd [Re: Bob's71R/T] #583802
01/15/10 11:11 PM
01/15/10 11:11 PM
WA 98043
thecarfarmer Offline
WA 98043
Do you need advice on how to R&R the trans, how to fix it, or both?
If it's advice pulling the trans, that's a big job, but not too tough for a first-timer... if you get a manual, have a good space, and plan on a weekend.
If it's advice on how to rebuild the trans, that's a little more involved (not a great job for a beginner). Having the correct year FACTORY manual, and a digital camera is a very good idea. Having a good 'surgically' clean area is darn near a necessity.
Trust me, you don't want to take the transmission apart, and let it sit a couple weeks... DAMHIK.
If you need advice on how to remove/install the trans, it's probably a good idea to see if there's a moparts member in the are who has opened one up before you take it apart. There isn't much magic in one, but it's a tricky enough thing that I wouldn't mind having an experienced person around when I work on one (and I have spent several years working on cars 40 hrs/week) to catch anything I miss - since it just ain't a kind of work I've done much of.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: 727 slipping between 2nd & 3rd [Re: thecarfarmer] #583803
01/15/10 11:32 PM
01/15/10 11:32 PM
Macomb,MI
Macomb,MI
Thanks Bill, but i've taken my trans out of my 65 appr 3 times and rebuilt it..my Challenger only once,i guess my question is why am i having a problem..is it the brake torque burn outs..i guess i do torcher my trans..i guess it's my fault..i've been working on cars since 67..Thank You Moparts.i think i'll pull my trans soon
Re: 727 slipping between 2nd & 3rd [Re: Bob's71R/T] #583804
01/16/10 12:32 AM
01/16/10 12:32 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
If you do not have the bigger Clutch Drum that has more clutches I would get one. Do you use Kevlar Clutches when you build them (different opinions on them). Try to stay off the Power Brake Burnouts. If you need to get the engine RPM up on the line, get a bigger stall convertor.
If you want to sit and burn the tires use a line lock. As far as shifting, do you use a manual valve body or do you have your kickdown linkage?
Valve body and line pressure make a big difference on shifts. Be patient and watch for replies and advise here. There are a lot of really good tranny guys on hear. Way better than me!!!
Re: 727 slipping between 2nd & 3rd [Re: joewhite440] #583805
01/16/10 12:48 AM
01/16/10 12:48 AM
Macomb,MI
Macomb,MI
wow yes i do still have my kick down linkage i never thought of that ..could that be my problem i did install kevlar clutches and bands from Mancinis 2 years ago?
Re: 727 slipping between 2nd & 3rd [Re: Bob's71R/T] #583806
01/16/10 02:50 AM
01/16/10 02:50 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I always ran a Turbo Action Cheeta Manual Valve bodys on anything that made big HP. It probably is your problem with that 2nd to 3rd Shift if the rest of the tranny is fresh. I think you would have noticed if there was any warn out grooves or cracks in your case. As well as seal leaks, clearances or etc in your trans when you rebuilt it.
I do not know what to tell you but it is probably Valve Body related which includes the kickdown.(Manual valvebodies dont use them) Maybe one of the tranny experts on here will chime in and help you out. Sorry I am not more help. These are good transmissions and work well. It is not the way you are beating them. You just need to build them to take the beating!
Watch for replies from others, someone will help out.
Joe Sr
