Re: What type of gear lube for a Dana 60 ?
[Re: LYNCHROAD69.5]
#583725
04/18/10 06:44 PM
04/18/10 06:44 PM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
I used Valvoline 75W-140 fully synthetic gear oil and bought a tube of limited slip addative....all at NAPA. BTW not cheap...about $75 but I will probably never change it in my lifetime.
is that limited slip additive synthetic also?
[Re: Blakcharger440]
#583727
04/18/10 08:49 PM
04/18/10 08:49 PM
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
Is it recommended to run a limited slip in all Dana 60 housings. Both Trak Loc and Power Loc?
yes i know that but what i am getting at is .......is the additive synthetic also.....your not suppose to mix synthetic with a non-synthetic right??
[Re: GEORGE68HEMIRR]
#583728
04/18/10 10:47 PM
04/18/10 10:47 PM
Posts: 2,405 Wichita,KS
Blakcharger440
Wichita,KS
Actually I was asking a question on whether all Dana 60's need the additive?
I think you are correct about not mixing synthetic and nonsynthetic fluids.
[Re: ahy]
#583730
04/19/10 12:42 AM
04/19/10 12:42 AM
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
The additive is the same for regular and synthetic gear oils. No problem mixing. The synthetic oils themselves have additive packages with conventional oil base.
The D60 needs the LS additive if it is a sure grip. Otherwise, regular gear oil will work fine by itself - like any other rear.
thanks ....i just changed over to synthetic on my D60 and was worried it would mix....cool
[Re: ahy]
#583732
04/20/10 08:10 PM
04/20/10 08:10 PM
Blakcharger440
Wichita,KS
My Charger has the Dana 60 Trak Lok...is that the same as the sure grip and do I need the additive?
