Anti Pump Up Lifters? #583716
01/15/10 08:24 PM
01/15/10 08:24 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
How much RPM can be gained (until valve float) by switching to anti pump up lifters, while keeping the same valve springs. For example, if my stock 340 starts to float @ 5500 RPM, what RPM would it start to float at, by switching to these anti pump up lifters? I realize that I would have to change my push rods and go to adjustable rockers. Thanks.
Re: Anti Pump Up Lifters? [Re: ragtop] #583717
01/15/10 08:49 PM
01/15/10 08:49 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
If you're getting valve float at 5500 rpm, you might want to consider new valve springs. Every standard hydraulic lifter engine I ever had big block or small block would easily rev past 6000rpm with a performance cam and the appropriate springs.
Re: Anti Pump Up Lifters? [Re: ragtop] #583718
01/15/10 08:49 PM
01/15/10 08:49 PM
Az
Crizila Offline
Crizila  Offline
Az
5500rpm
Fastest 300
Re: Anti Pump Up Lifters? [Re: Crizila] #583719
01/15/10 10:05 PM
01/15/10 10:05 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Lifter pump up is caused by valve float. The valve floats, the lifter pumps up to take up the slack, the valve doesn't shut. No more RPM.
