Direct Connection SB rod part # #583577
01/15/10 05:29 PM
01/15/10 05:29 PM
Canada
RobR Offline OP
RobR  Offline OP
Canada
I have a little time capsule from the 70's...a complete small block with an 8 bolt crank..and what looks like a nice set of what must be Direct Connection connecting rods (very nicely finished)and Arias pistons all toped off with a nice ported set of X heads from Ron's Porting.
The engine has a roller cam in it with what looks like those old Crane bar & clip roller lifters in it...and the icing on the cake a mint set of fender well headers for a 65 Cuda..
Now back to my question...does anyone have a Early 70's Direct Connection catalog that might show the casting or part number for small block connecting rods?
Any help would be muchly appreceated...
Rob
Re: Direct Connection SB rod part # [Re: RobR] #583578
01/15/10 06:04 PM
01/15/10 06:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two rods listed in 78 DC catalog.# P3690641,magnafluxed,double shot peened and high strength bolts and nuts.Other is all out race rod Pt # 3614514 specail heavy duty forging with 7/16" bolts
Re: Direct Connection SB rod part # [Re: 62maxwgn] #583579
01/15/10 08:38 PM
01/15/10 08:38 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
the 514 rods were/are called small block hemi footprint rods due to the big end appearence looking like a hemi rod does. a very stout rod but heavy. i used them with a standard 340 crank and 12to 1 trw's with cut down domes and had to add mallory to the crank to balance it. this was a nascar rod.
Re: Direct Connection SB rod part # [Re: 3ddart] #583580
01/16/10 12:45 PM
01/16/10 12:45 PM
Canada
RobR Offline OP
RobR  Offline OP
Canada
Thanks Guys..!! there's no 7/16 bolts in these rods they look like old SPS bolts...
These rods are finished like a Pro billet I beam but they have a number running the length of the beam.
This engine might be some kinda short stroke deal.
When I knock it apart I'll post up some pictures and then the small block guys will have a better idea of what I have.
Thanks again...
