Re: Where do you get dip stick delete plug?
[Re: 452RT]
#58333
05/12/08 09:54 AM
05/12/08 09:54 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Don't delete it... wave guide tune it!
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: 452RT]
#58336
05/12/08 10:46 AM
05/12/08 10:46 AM
I have one that I won't be using on a '78 440 truck motor.
It's going in a car chassis.
The motor is disassembled and sitting on the stand right now.
If you know how it comes out (pressed or threaded) let me know and I'll box it up and send it to you.
[Re: 452RT]
#58339
05/12/08 03:30 PM
05/12/08 03:30 PM
I actuly just fill the hole with nickumpucky (Right stuff)never had a leak.
#58340
05/12/08 04:18 PM
05/12/08 04:18 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
sillycone works too as long as your combo doesnt build to muck cranck case press.
[Re: marvo451]
#58341
05/12/08 08:50 PM
05/12/08 08:50 PM
I just tapped it for 1/8 NPT and used a pipe plug.
#58342
05/12/08 09:06 PM
05/12/08 09:06 PM
Posts: 659 Tampa Fl
kens avenger
mopar addict
mopar addict
Tampa Fl
think they came with mildon pans..31161 you could call milodon.. or PM me i have one from a motor we did.. we tap and plug them now like what was said
Remember in here some don't think you should have a Opinion.. sad fact..
#58343
05/12/08 09:08 PM
05/12/08 09:08 PM
I use some two part epoxey...Works well.. poppaj
[Re: Al_Alguire]
#58346
04/27/09 10:06 PM
04/27/09 10:06 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I just find a bolt that slips into the hole, put some JB Weld on the bolt, and stick it into the hole. Won't blow out, but you can remove it if you ever want to by turning the bolt with a wrench to break loose the sealant.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
