Where do you get dip stick delete plug? #58332
05/12/08 09:50 AM
05/12/08 09:50 AM
Kauai, Hawaii
452RT Offline OP
452RT  Offline OP
Kauai, Hawaii
I have no need for a dip stick an in the past my other race engines had a delete plug in it's place, I just don't know where or remember where I got them. Help my memory, thanks.
Re: Where do you get dip stick delete plug? [Re: 452RT] #58333
05/12/08 09:54 AM
05/12/08 09:54 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Don't delete it... wave guide tune it!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Where do you get dip stick delete plug? [Re: 452RT] #58334
05/12/08 09:56 AM
05/12/08 09:56 AM
AndyF Offline
AndyF  Offline
It is a factory part that was used on the pickup trucks with the rear sump but I don't think it is available over the counter anymore. Last time I needed one I just turned on one the lathe. I don't know if anyone makes these or not.
Re: Where do you get dip stick delete plug? [Re: AndyF] #58335
05/12/08 10:00 AM
05/12/08 10:00 AM
Kauai, Hawaii
452RT Offline OP
452RT  Offline OP
Kauai, Hawaii
Wish I had saved some of those I had thrown out. Guess I will just turn one down. Thanks.
Re: Where do you get dip stick delete plug? [Re: 452RT] #58336
05/12/08 10:46 AM
05/12/08 10:46 AM
I have one that I won't be using on a '78 440 truck motor.
It's going in a car chassis.
The motor is disassembled and sitting on the stand right now.
If you know how it comes out (pressed or threaded) let me know and I'll box it up and send it to you.
Re: Where do you get dip stick delete plug? #58337
05/12/08 10:51 AM
05/12/08 10:51 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
I just tapped it for 1/8 NPT and used a pipe plug.
Re: Where do you get dip stick delete plug? #58338
05/12/08 11:13 AM
05/12/08 11:13 AM
AndyF Offline
AndyF  Offline
They press in. Just tap it from the bottom side with a dowel pin or a reamer blank and it will come out.
Re: Where do you get dip stick delete plug? [Re: 452RT] #58339
05/12/08 03:30 PM
05/12/08 03:30 PM
I actuly just fill the hole with nickumpucky (Right stuff)never had a leak.
Re: Where do you get dip stick delete plug? #58340
05/12/08 04:18 PM
05/12/08 04:18 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sillycone works too as long as your combo doesnt build to muck cranck case press.
Re: Where do you get dip stick delete plug? [Re: marvo451] #58341
05/12/08 08:50 PM
05/12/08 08:50 PM
Re: Where do you get dip stick delete plug? #58342
05/12/08 09:06 PM
05/12/08 09:06 PM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
think they came with mildon pans..31161
you could call milodon.. or PM me i have one from a motor we did.. we tap and plug them now
like what was said
Remember in here some don't think you should have a Opinion.. sad fact..
Re: Where do you get dip stick delete plug? #58343
05/12/08 09:08 PM
05/12/08 09:08 PM
I use some two part epoxey...Works well.. poppaj
Re: Where do you get dip stick delete plug? #58344
04/27/09 07:20 PM
04/27/09 07:20 PM
Missouri
P
Promopar Offline
Promopar  Offline
P
Missouri
I'm also needing one of the factory plugs. Anyone who has one can PM me with a price. Thanks, James
Re: Where do you get dip stick delete plug? [Re: Promopar] #58345
04/27/09 07:26 PM
04/27/09 07:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You get them from Chevy guys
You still headed down this way? Oh yeah not sure if you heard or not but lilDemon is down. Sounds like planetaries in the trans
Re: Where do you get dip stick delete plug? [Re: Al_Alguire] #58346
04/27/09 10:06 PM
04/27/09 10:06 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I just find a bolt that slips into the hole, put some JB Weld on the bolt, and stick it into the hole. Won't blow out, but you can remove it if you ever want to by turning the bolt with a wrench to break loose the sealant.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Where do you get dip stick delete plug? [Re: 452RT] #58347
04/27/09 10:12 PM
04/27/09 10:12 PM
Renton Washington
Triple Threat Offline
Renton Washington
Dipstick Delete ? Well then who is gonna drive the car Jim?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Where do you get dip stick delete plug? [Re: Triple Threat] #58348
04/27/09 10:51 PM
04/27/09 10:51 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
