Anyone use this Lunati Roller? #582519
01/14/10 07:16 PM
01/14/10 07:16 PM
tboomer Offline OP
tboomer  Offline OP
Re: Anyone use this Lunati Roller? [Re: tboomer] #582520
01/14/10 07:29 PM
01/14/10 07:29 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What engine Ted? What heads? How do the flow? Whats the compression of the engine...I forget...
Re: Anyone use this Lunati Roller? [Re: Bob_Coomer] #582521
01/14/10 07:34 PM
01/14/10 07:34 PM
tboomer Offline OP
tboomer  Offline OP
Bob...446"...I don't have pistons yet. The heads are 80cc MPs...
Re: Anyone use this Lunati Roller? [Re: tboomer] #582522
01/14/10 07:55 PM
01/14/10 07:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Re: Anyone use this Lunati Roller? [Re: Bob_Coomer] #582523
01/14/10 08:22 PM
01/14/10 08:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
This one looks better IMO
http://www.summitracing.com/parts/CCA-23-706-9/
I think the other one is to small. If your going to the expense of a roller for a race engine id want at least 260@ 050.
265* rollers @ .050 can support over 700+ HP, this cam should be plenty for you Ted. I like it!
Pick a piston of around min of 11.5 or so. More would work even better. But if you had to run pump gas that cam should still rock at 10.7 or so. mike
Re: Anyone use this Lunati Roller? [Re: Sport440] #582524
01/14/10 08:51 PM
01/14/10 08:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Couldnt have said it better...
That cam's lift will clear about any modern piston valve reliefs Ted.
The problem I see with flat tops and stock stroke engines is getting good compression. With 80cc chambers with Zero deck pistons and minimal valve reliefs your going to struggle to get the compression up over 11:1.
This is a pretty much a race car only isnt it Ted?
Ross makes some shelf Domes, and IIRC so does Keith Black in the forged line...
A Dome piston could be worth as much as 50hp in that type of engine with a roller cam...
Re: Anyone use this Lunati Roller? [Re: Bob_Coomer] #582525
01/14/10 09:32 PM
01/14/10 09:32 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Bob goin from 11 to 1 to 13.5 could be worth that nuch
Re: Anyone use this Lunati Roller? [Re: cbarracuda] #582526
01/15/10 12:42 PM
01/15/10 12:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
13.5:1 compression would be in the ball park of most good effort output engine.
Its a proven power increase of 5%-7% many times over..
Well it would be minimal of 25-30HP. Like I say it depends on the combo. In a case were the cam and a few things arent idea, it could make a good diff in E/T..in which that is what were after...not estimated HP figures.
I was just saying if I could pickup a set of domes in the same price range..It would be a no brainer..
