Front Drum brakes #582347
01/14/10 04:21 PM
01/14/10 04:21 PM
Long Island, New York
Tony H Offline OP
Tony H  Offline OP
Larger shoe material to the rear of the car?
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
Re: Front Drum brakes [Re: Tony H] #582348
01/14/10 04:23 PM
01/14/10 04:23 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yep
Re: Front Drum brakes [Re: buildanother] #582349
01/14/10 10:10 PM
01/14/10 10:10 PM
Az
Crizila Offline
Crizila  Offline
Az
Yep
- but do you know why
Fastest 300
Re: Front Drum brakes [Re: Crizila] #582350
01/14/10 10:35 PM
01/14/10 10:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
They are self-energizing design. This means that as they apply, the leading shoe drags against the drum. Since the top is against a solid anchor, the shoe tries to move with the direction of the drum and rotates toward the bottom, pushing against the rear shoe. This added force applies the rear shoe harder. Since it does more of the braking, the rear shoe should be larger.
Re: Front Drum brakes [Re: RodStRace] #582351
01/14/10 11:30 PM
01/14/10 11:30 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
That all said, putting the bigger shoe to the rear only matters if the system IS self energizing.
Not all of them are. I'm not sure how early you have to go to find ones that aren't, but it's not that early.
Re: Front Drum brakes [Re: dave571] #582352
01/15/10 10:33 AM
01/15/10 10:33 AM
Minn
SportF Offline
SportF  Offline
Minn
1962 I believe. The earlier cars with the two cylinders on the backing plate have equal size shoes. It was in 62 (+ or - a year or so)they paid Bendix for the right to use the "servo apply" or "servo action" brake shoe apply type. They didn't want to do that and prior to that they had the two wheel cylinders and/or some pretty big drums, but they weren't as good as the Bendix system. GM had the same problem in the early 60's which is why they had some of those aluminum finned 12 inch 2-3 inch wide drums on the big cars. When they finally went to the servo action they got rid of a lot of front end weight. This is all written down somewhere on the net and makes for some interesting reading, especially the way Chrysler tried to avoid paying Bendix for the right to use their patent method. Somebody feel free to correct me on the years or names this brake method, as this is all from Memory from 40 years ago told to me by my auto shop instructor who was privy to this information as it happened in the late fifties.
Re: Front Drum brakes [Re: SportF] #582353
01/15/10 11:20 AM
01/15/10 11:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kids 62 has the dual whl cyls as did my 57.The rears are the same shoes as fronts but use a single cylinder.Rocky
Chrysler Firepower
Re: Front Drum brakes [Re: therocks] #582354
01/15/10 12:06 PM
01/15/10 12:06 PM
Minn
SportF Offline
SportF  Offline
Minn
I'll bet the '62 is a "C" body??
Re: Front Drum brakes [Re: RodStRace] #582355
01/15/10 01:06 PM
01/15/10 01:06 PM
Az
Crizila Offline
Crizila  Offline
Az
WOW - on the $!
Fastest 300
Re: Front Drum brakes [Re: Crizila] #582356
01/15/10 01:58 PM
01/15/10 01:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Techinacly there were no C bodies in 62.It is a 300 though.The 62 Dodge and the 61 we had had the same brake setup.Its been too many years for me to remember what brakes the 63 I had were.Rocky
Chrysler Firepower
THANKS [Re: Tony H] #582357
01/16/10 12:21 PM
01/16/10 12:21 PM
Tony H Offline OP
Tony H  Offline OP
Just making I'm not repeating a P.O. screw up
'89 Volvo
