Rolling a bead into copper pipe
#581388
01/13/10 06:55 PM
01/13/10 06:55 PM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
I've got a '68 Sweptline and I'm replacing the heater control valve and the heater core. The control valves aren't made any more. I have to use a generic control valve and add a tube to it to go through the firewall. The stock tubes have a lip rolled into the pipe. I've been to machine shops, old school car shops, and radiator shops and no one seems to have the equipment to roll the bead into the copper pipe to make it like stock. I know that: 1) Eastwood sells equipment to do this but I ain't spending $600 to roll two beads 2) I could just flare it. I want this to be as original as possible but if I cannot find someone that can roll the bead in then I will just flare it. If there is a shop or person in the Atlanta area, heck, a shop or person within a 200 mile radius of Atlanta that can do this, let me know. Here's what the stock end looks like: ![](http://farm3.static.flickr.com/2796/4272087085_52ea74af2a.jpg)
Re: Rolling a bead into copper pipe
[Re: Chilort]
#581390
01/13/10 07:59 PM
01/13/10 07:59 PM
RapidRobert
A slight flare of just the right amount & it will not leak and it would be hidden if you could live w that
[Re: Chilort]
#581393
01/13/10 08:34 PM
01/13/10 08:34 PM
RapidRobert
yeah I wanted to roll a bead on some tubing pieces to fab some custom radiator hose routing and Eastwoods price stopped me dead in my tracks ![](/ubbthreads/images/graemlins/blush.gif) . I hear their stuff is top notch but like you I'd only be rolling several beads.
[Re: Stanton]
#581398
01/13/10 09:37 PM
01/13/10 09:37 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Are you going to leave it exposed? 'Cause if not, who the hell's going to know it doesn't have a bead ?!?!?
The bead helps retain the hose against the clamp, and keeps it from "creeping" under pressure, which would result in a "blown" hose down the road eventually if there's no bead to offer resistance,...if it wasn't needed, manufacturers wouldn't waste their time forming it, like the Sun, it's there for a reason ![](/ubbthreads/images/graemlins/beer.gif)
[Re: wedgg440]
#581401
01/13/10 10:16 PM
01/13/10 10:16 PM
Posts: 15,487 Florida
scratchnfotraction
thats a good idea ![](/ubbthreads/images/graemlins/thumbs.gif) old mopar man ![](/ubbthreads/images/graemlins/bow.gif) must have been around the block a time or two and been there done that hardware store in the plumbing section for a ferrule that size ![](/ubbthreads/images/graemlins/scope.gif)
[Re: RapidRobert]
#581402
01/13/10 10:53 PM
01/13/10 10:53 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Eastwoods price stopped me dead in my tracks . I hear their stuff is top notch...
HA!! I bought one of their bead rollers once. When it arrived it was the same one my friend had from Harbor Freight!!! ![](/ubbthreads/images/graemlins/maad.gif)
[Re: wedgg440]
#581403
01/13/10 11:22 PM
01/13/10 11:22 PM
Chilort
Cookeville
Another way to accomplish what your trying to do is to see if you can find a brass ferrule to fit your tubing and just solder it on the tube.
I can find a ferrule that size. It is something a few people recommended. ... it would be cheaper. A pack of two ferrules was about $2.50. I've already got the propane torch and solder.
[Re: PhillyRag]
#581407
01/14/10 08:57 AM
01/14/10 08:57 AM
Chilort
Cookeville
Ferrule is what I had in mind. The copper ring would be great if OD of tubing isn't an aval. ferrule size.
I considered going this route but at the two hardware stores I went into (big box type) I couldn't find unions that had free ferrules. All of the ferrules were captured in the compression nut.
I love Ghettobeader.
