1973 charger 400 no PCV valve #580449
01/12/10 04:07 PM
01/12/10 04:07 PM
Riverside R.I. U.S.A.
suit-case Offline OP
I have a 73 dodge charger with a 400.It has after market valve covers and air cleaner.There isn't a place for a pcv valve,just a breather type cover on the valve cover.Does this matter or make a differance.
Re: 1973 charger 400 no PCV valve [Re: suit-case] #580450
01/12/10 05:36 PM
01/12/10 05:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes, if you don't want oil all over everywhere you need a breather on one side and a PCV on the other.
Re: 1973 charger 400 no PCV valve [Re: stumpy] #580451
01/12/10 05:46 PM
01/12/10 05:46 PM
what Stumpy said. See if the other valve cover is one that has a spot on top for a pcv hole to be drilled & best would be to weld in some baffles underneath it.
Re: 1973 charger 400 no PCV valve [Re: stumpy] #580452
01/12/10 07:33 PM
01/12/10 07:33 PM
Thank you very much sounds good.
