70 and 71 ebody console #580036
01/11/10 11:11 PM
01/11/10 11:11 PM
Rochester,MN
Sixpackman340 Offline OP
I'll wait forever
I'll wait forever
Rochester,MN
Can anyone give me the low down on the wood grain top plate from a 71 console fitting a 70? If my memory serves me well I think the 71's have four holes? Is the door the same?
Re: 70 and 71 ebody console [Re: Sixpackman340] #580037
01/11/10 11:33 PM
01/11/10 11:33 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
71-4 has a plate screw next to the shifter as where 70 doesn't.
71-4 has a rear ash tray and 70 has a hole for the seat belts.
Think the doors are the same but not positive.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 70 and 71 ebody console [Re: moparmarks] #580038
01/11/10 11:41 PM
01/11/10 11:41 PM
Rochester,MN
I'll wait forever
I'll wait forever
Rochester,MN
does anyone know if there are repo topplates for the 70 console?
Re: 70 and 71 ebody console [Re: Sixpackman340] #580039
01/11/10 11:57 PM
01/11/10 11:57 PM
moparmarks Offline
moparmarks  Offline
Check with Tony's Parts and BE/A
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70 and 71 ebody console [Re: moparmarks] #580040
01/12/10 12:05 PM
01/12/10 12:05 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Woodgrain is the same shape for all years (though different for auto v. 4-speed). No reason you couldn't fill the etra hole before applying the decal.
I have seen '70 style consoles as original equipment in '71s through build dates of Nov '70 (both b + e body)
Re: 70 and 71 ebody console [Re: Sixpackman340] #580041
01/12/10 02:46 PM
01/12/10 02:46 PM
central new york
pettyblue440 Offline
central new york
I believe my 70 weldtech repro is a 70 style
Re: 70 and 71 ebody console [Re: pettyblue440] #580042
01/12/10 04:26 PM
01/12/10 04:26 PM
Rochester,MN
I'll wait forever
I'll wait forever
Rochester,MN
I've got a nice 71 plate, I will probably try to fill the one hole and sand it out smooth and apply the decal. What do you guys think would work good for this? solder, epoxy, bodyfiller?
Re: 70 and 71 ebody console [Re: Sixpackman340] #580043
01/13/10 10:39 PM
01/13/10 10:39 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Epoxy works best, but a bit of roughing up helps. Best to let it sit awhile for shrinkage than sand. BTW I thought the woodgrain was a bit "grainy" for the 1970 plates?
Re: 70 and 71 ebody console [Re: YYZ] #580044
01/13/10 10:47 PM
01/13/10 10:47 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Vlad- my '71 GTX with an SPD of C17 also came with the '70 style console. The lastest date I have seen personally so far.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
