Re: what to do, high mile trans and pan swap
[Re: pettyblue440]
#579357
01/11/10 12:19 AM
01/11/10 12:19 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I don't buy that, just put new fluid back in there of the correct type. ![](/ubbthreads/images/graemlins/Twocents.gif) Change filter too.
[Re: pettyblue440]
#579358
01/11/10 12:19 AM
01/11/10 12:19 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I have a 98 durango with close to 160k on it. The trans pan has a rust hole in the side and I am losing fluid out of it. I have read that changing the fluid on a high millage trans can cause problems. If I decide to replace the pan, should I try to "catch" the fluid and put it back in when the new pan is on? Thanks-Jon
If you do reuse it....at least run it through a paint strainer.
[Re: pettyblue440]
#579360
01/14/10 07:10 PM
01/14/10 07:10 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
It's your call , I personally know of 2 people that I advised against changing the fluid , one was a 76 pontiac with only 60k miles , but the car was almost 20 yrs old , the trans went out a couple weeks later , the other was an 85 bmw 5 series with almost 200k on it , the trans was starting to slip , the fluid change was the nail in the coffin for that one .
