Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579341
01/12/10 07:23 PM
01/12/10 07:23 PM
Jacksonville, Fl.
jax 70 cuda Offline
jax 70 cuda  Offline
Jacksonville, Fl.
Procharger!! A good friend has a 68' Camaro with a 337" small block. It makes right at 1000hp runs on pump gas and cruises all over town every weekend. When he takes it to the strip he turns up the boost dumps in race gas and clicks off 8.60s in the quarter!!
Re: What build would make the most RELIABLE 1000hp SB? [Re: jax 70 cuda] #579342
01/12/10 08:33 PM
01/12/10 08:33 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Reliable Streetable. That rules out most any comp. engine.
Ole NASCAR engines. You can't get much more reliable than an engine that can run 500 miles at high RPM.
PUMP GAS
Swap out the pistons and put any kinda forced induction and 1,000 HP will seem like a joke.
Oh you said money was no object!
Then buy the best turbo, fuel injection, and boost management money can buy.
