440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs #577040
01/08/10 10:32 PM
01/08/10 10:32 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
I have a 70 Challenger R/T 440 4bbl that I will be changing over to a six pack soon.
What is the correct order for the fuel line parts?
fuel tank, fuel lines, fuel filter, fuel pump, fuel vapor separator, carburetors
Thanks, Rob
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577041
01/08/10 10:57 PM
01/08/10 10:57 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Not sure what you're asking...Mabe factory routing ???...Fuel tank should have the 3/8 sender with the return....Fuel exits tank,enters the fuel pump and gets pumped through the vapor separator where a certain percentage gets returned through the 1/4 inch return line...The rest goes to the carbs....
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: screamindriver] #577042
01/09/10 07:30 AM
01/09/10 07:30 AM
Williamsport, PA
mopar addict
mopar addict
Williamsport, PA
Let me try to ask it a different way. Once the fuel makes it to the engine compartment, what is the correct order or sequence for the fuel filter and fuel vapor separator to be mounted.
I currently have a fuel filter then the fuel pump then fuel vapor separator followed by the carbs. (fuel lines in between).
Is it okay to have the fuel filter before the fuel pump or will that restrict fuel or should that be after the fuel pump?
I know the fuel vapor separator is supposed to be between the fuel pump and the carburetors.
Thanks, Rob.
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577043
01/09/10 08:18 AM
01/09/10 08:18 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Rob,
No filter before the pump from the factory.
The separator is your filter
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577044
01/09/10 08:27 AM
01/09/10 08:27 AM
Long Island NY
yellow sixpack Offline
Long Island NY
Here is a pic for you.
If you can't be smart.....don't be stupid!
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577045
01/09/10 09:30 AM
01/09/10 09:30 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Unless you would be assembling this for show,
which you aren't or you wouldn't be changing
intakes, I have installed filters before the
pump as you indicated in your first post.
I have never taken apart a vapor seperator
but I think it's just a screen filter.
The filter ahead of the pump will protect
the pump as well as the seperator & carbs.
The trucks just prior to f.i. had the filter
before the pump.
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: demonH1B] #577046
01/09/10 12:23 PM
01/09/10 12:23 PM
Harrisburg, Pa.
Harrisburg, Pa.
It's all about filtering vs restriction...Technically the first factory filter could be the sending unit sock in the tank...But if you're not using one or are unsure if it's there...The easy way out{as already stated} would be to add a filter at the rubber hose between the hard line and the fuel pump..Probably the worst place for the pump itself for performance but considering the rest is all hard line.. .. All you can do is get a good filter with the least amount of restriction...
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: screamindriver] #577047
01/09/10 02:19 PM
01/09/10 02:19 PM
Williamsport, PA
mopar addict
mopar addict
Williamsport, PA
I have a brand new sending unit and fuel tank. Should I remove the fuel filter before the fuel pump and just use the fuel vapor separator after the pump?
Thanks, Rob
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577048
01/09/10 02:45 PM
01/09/10 02:45 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
I use the seperator as I wanted to maintain original design, but I know others put a filter in-line (top-side) after the pump before the carbs. The sending unit sock should screen out junk that could cause fuel pump problems.
Re: 440 Fuel Vapor Separator, Fuel Filter, Fuel Pump, Carbs [Re: Rob440Magnum] #577049
01/09/10 08:01 PM
01/09/10 08:01 PM
Harrisburg, Pa.
Harrisburg, Pa.
Rob, I'd leave the fuel filter before the pump if you're going to add everything new...I do that when everything is replaced and I've caught some junk that would have ended up in the vapor separator...You'd think with all parts being new that everything is clean but small amounts of dirt, rubber,plating etc... can be initially caught...After a few miles of running you can easily change out the filter with a straight run of hose if you want...That's my ....
