Steering Column Separator Tool #576968
01/08/10 08:22 PM
01/08/10 08:22 PM
Oh
I
ipstrategies Offline OP
I
Oh
I am taking my steering column apart (71 charger). I used a wheel puller to take off the Wheel and removed the Turn Signal.
I removed the 3 outer screws and the Snap Ring on the steering shaft, the book shows a tool called a Steering Column Separator Tool. I can not find this tool and wonder what everyone else does.
I need to get this apart so it can be painted along with dash and given back to shop so I can get my car from metal shop.
Thanks for the help
Re: Steering Column Separator Tool [Re: ipstrategies] #576969
01/08/10 08:28 PM
01/08/10 08:28 PM
ne
broncobra Offline
broncobra  Offline
ne
I studied the picture in the service manual and built my own using a piece of pipe and a couple pieces of metal and a nut. It is a very simple tool to make if you have a welder. Use the three original screws you took out to bolt it in place.
Re: Steering Column Separator Tool [Re: broncobra] #576970
01/08/10 08:36 PM
01/08/10 08:36 PM
Oh
I
I
Oh
would you have a picture?
Re: Steering Column Separator Tool [Re: ipstrategies] #576971
01/08/10 08:54 PM
01/08/10 08:54 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70 FSM
Re: Steering Column Separator Tool [Re: Snoopy] #576972
01/09/10 12:58 PM
01/09/10 12:58 PM
Snoopy Offline
Snoopy  Offline
The real deal.
Let me know if you need any more measurements.
O.D. = 2.0625"
Re: Steering Column Separator Tool [Re: Snoopy] #576973
01/09/10 12:58 PM
01/09/10 12:58 PM
Snoopy Offline
Snoopy  Offline
Barrel Dia. = 1"
Barrel O.A.L = 2.880"
Bolt O.A.L = 2.5"
Thread = 3/8"-16
Re: Steering Column Separator Tool [Re: Snoopy] #576974
01/09/10 12:59 PM
01/09/10 12:59 PM
Snoopy Offline
Snoopy  Offline
O.D. = 2.0625"
I.D. = 0.7560"
Re: Steering Column Separator Tool [Re: Snoopy] #576975
01/09/10 01:44 PM
01/09/10 01:44 PM
Snoopy Offline
Snoopy  Offline
This is full size. Print it out, make sure the O.D. is 2 1/16" and use it as a template. The screw holes are 3/16" or #10.
Re: Steering Column Separator Tool [Re: Snoopy] #576976
01/09/10 01:54 PM
01/09/10 01:54 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
here is a pic of my homade one. pretty simple.
Re: Steering Column Separator Tool [Re: macmic87] #576977
01/09/10 02:09 PM
01/09/10 02:09 PM
Snoopy Offline
Snoopy  Offline
Re: Steering Column Separator Tool [Re: Snoopy] #576978
01/09/10 06:07 PM
01/09/10 06:07 PM
ne
broncobra Offline
broncobra  Offline
ne
All I did was take a piece of pipe and weld a nut on the the top and a large washer on the bottom and drilled the holes for the three screws, and got a long bolt. I could show you pics, but you would cringe at how crude it is! lol. It is VERY simple. Keep in mind, you need a tool that does the exact opposite when you go back together. I haven't made that one yet. The one to take it apart is like a steering wheel puller in minature. The one to put it back together is a small press. Just a nut and bolt on a pipe. if you really still want pics, I will take them and post. It looks like a caveman made it, but it worked and was free.
Re: Steering Column Separator Tool [Re: macmic87] #576979
01/09/10 06:09 PM
01/09/10 06:09 PM
ne
broncobra Offline
broncobra  Offline
ne
Yours is very nice! I didn't have a welder at the time and had a farmer buddy stick weld mine.
Re: Steering Column Separator Tool [Re: broncobra] #576980
01/09/10 07:26 PM
01/09/10 07:26 PM
Snoopy Offline
Snoopy  Offline
Installation instructions.
Re: Steering Column Separator Tool [Re: Snoopy] #576981
01/09/10 07:28 PM
01/09/10 07:28 PM
Snoopy Offline
Snoopy  Offline
C-3879 Installation tool.
Length = 1.750"
O.D. = 1"
I.D. = .757"
Re: Steering Column Separator Tool [Re: ipstrategies] #576982
01/14/10 09:06 AM
01/14/10 09:06 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
They are listed in the moparts tools and equiptment section 1st quarter. They have a a fine thread 1/2 20 and are made from HRS steel. I have other tools for your steering column rebuild project. Save money and do it yourself... Thanks John 843-324-3586 jrivinius@sc.rr.com www.stores.ebay.com/johnscudashop
Re: Steering Column Separator Tool [Re: macmic87] #576983
01/16/10 12:48 AM
01/16/10 12:48 AM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
yep...this is exactly how to make it easy. Works perfectly. Identical to mine...save time and money
Persistance is omnipotent Durability Engineer, Chair and Couch division...
