Air Grabber Hole #576673
01/08/10 04:05 PM
01/08/10 04:05 PM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Can anybody either show me a picture or give me an idea where the air grabber hole in the firewall
is on a 69 runner.
Thank You
Bruce
Re: Air Grabber Hole [Re: a4runer] #576674
01/08/10 07:19 PM
01/08/10 07:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You just had to look in the Resto/A12 section,....I pirated the pic for you
Re: Air Grabber Hole [Re: DAYCLONA] #576675
01/08/10 10:42 PM
01/08/10 10:42 PM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Thank You for the picture it will help alot. I did not think to search the topic ,which I will do in the future.....Thanks again
Re: Air Grabber Hole [Re: a4runer] #576676
01/08/10 10:52 PM
01/08/10 10:52 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Here is a link to that thread:
https://board.moparts.org/ubbthreads/show...e=0#Post5712885
There is a good picture of a bare firewall with the hole in that thread...
XS
Re: Air Grabber Hole [Re: a4runer] #576677
01/08/10 11:22 PM
01/08/10 11:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you will see a dimple in the firewall where that hole is supposed to be , it was punched , not drilled , you can do the same thing with a greenlee punch , drill a small pilot holt and use the punch to make the big hole .
Re: Air Grabber Hole [Re: JohnRR] #576678
01/09/10 07:08 PM
01/09/10 07:08 PM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Thanks all for the help.I drilled the hole no punches here came out ok Thanks for your time and info.....
