wristpin bushings: .990 pin - LY rod? #575603
01/07/10 02:52 AM
01/07/10 02:52 AM
WA 98043
thecarfarmer Offline OP
WA 98043
I tried to get my friend to pop for a set of aftermarket rods for a 440 Chrysler build... no dice.
He gave me a bunch of LY rods, and some ARP bolts.
Rods magged fine; bolts went in and everything re-sized nicely.
But, I want to bush the big ends down for .990" pins.
IIRC, Summit had a bushing for this (made by Manley?); I haven't been able to find it again.
Anybody have suggestions?
TIA!
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: wristpin bushings: .990 pin - LY rod? [Re: thecarfarmer] #575604
01/07/10 03:05 AM
01/07/10 03:05 AM
tboomer Offline
tboomer  Offline
Ross also has these bushings, PN #B1094, $8.95 from Summitt.
Try this??
Re: wristpin bushings: .990 pin - LY rod? [Re: tboomer] #575605
01/07/10 01:17 PM
01/07/10 01:17 PM
WA 98043
WA 98043
Thanks for the heads up!
-Bill
Re: wristpin bushings: .990 pin - LY rod? [Re: thecarfarmer] #575606
01/07/10 02:03 PM
01/07/10 02:03 PM
organ
maximum entropy Offline
organ
i wouldn't do the big ends that small.
Re: wristpin bushings: .990 pin - LY rod? [Re: maximum entropy] #575607
01/07/10 08:10 PM
01/07/10 08:10 PM
ky
68roadrunner Offline
ky
mine came from probe pistons
Re: wristpin bushings: .990 pin - LY rod? [Re: maximum entropy] #575608
01/07/10 09:30 PM
01/07/10 09:30 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
And I thought the Honda rod journal was small.
I think Diamond has some bushings for the pin end.
Floyd Lippencott IV
