Spring perches on the bottom of the axle? #575078
01/06/10 03:19 PM
01/06/10 03:19 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
I'm moving the spring perches anyhow and I was wondering if anyone has done this to lower their car. I've read the truck boards and this seems to be a common way to lower a truck.
Thoughts?
Re: Spring perches on the bottom of the axle? [Re: whitemtnelf] #575079
01/06/10 03:30 PM
01/06/10 03:30 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
They are already on the bottom with a car.
You can use lowering blocks, or some flip thier front spring hanger to lower the rear.
Re: Spring perches on the bottom of the axle? [Re: dave571] #575080
01/06/10 04:30 PM
01/06/10 04:30 PM
it'd change the height ~4.5". 3" for the housing dia and 1.5" for the perch height (~3/4" x2)
Re: Spring perches on the bottom of the axle? [Re: dave571] #575081
01/06/10 04:40 PM
01/06/10 04:40 PM
michigan woods
imfixinmopars426 Offline
michigan woods
old school lowering trick,BUT...they really fly out of there when pulling holeshots,so watch it.lol
Re: Spring perches on the bottom of the axle? [Re: imfixinmopars426] #575082
01/06/10 06:20 PM
01/06/10 06:20 PM
New Hampshire
W
W
New Hampshire
DOH! Got the truck and the car confused...
Too many things going on!
