Page 2 of 5 1 2 3 4 5
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574344
01/07/10 09:48 PM
01/07/10 09:48 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
e-85 is far from race gas. the thing is that a low compression edelbrock headed small block with a turbo would run 9.50s or even faster with out a lot of work as well. a pump gas n/a small block that runs deep into the nines is a bad a$$ ride no doubt about it, but I think you can go faster cheaper with a turbo
Re: any a-body turbo pictures? [Re: joshking440] #574345
01/07/10 09:58 PM
01/07/10 09:58 PM
ky
headhunter Offline OP
ky
heres a few pictures of what im workin with
Re: any a-body turbo pictures? [Re: headhunter] #574346
01/07/10 10:00 PM
01/07/10 10:00 PM
ky
ky
Re: any a-body turbo pictures? [Re: joshking440] #574347
01/07/10 10:02 PM
01/07/10 10:02 PM
Edmonton alberta Canada
mr. 63plymouth Offline
I totally agree, i'm just a simple clean kinda guy that doesnt like alot of stuff going on in an engine bay,plus a mid 9sec Street car is way more impressive then a mid 9sec turbo street car!!
Re: any a-body turbo pictures? [Re: headhunter] #574348
01/07/10 10:04 PM
01/07/10 10:04 PM
ky
ky
Re: any a-body turbo pictures? [Re: headhunter] #574349
01/07/10 10:09 PM
01/07/10 10:09 PM
ky
ky
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574350
01/07/10 10:12 PM
01/07/10 10:12 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i'm not doubting you have a nice fast car there but give more info such as weight, displacement and such. generally speaking just about any turbo setup is going to outrun a naturally aspirated one and have better manners.
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574351
01/07/10 10:13 PM
01/07/10 10:13 PM
ky
ky
ive had a mid 8 car that was simple and very clean and a blown inj street car and a hemi car that would run low nines on pump gas with a overdrive im just wanting to try a turbo. hopefully go mid nines with a hyd cam and steel ported heads cant do that nat aspirated
Re: any a-body turbo pictures? [Re: headhunter] #574352
01/07/10 10:16 PM
01/07/10 10:16 PM
ky
ky
Re: any a-body turbo pictures? [Re: headhunter] #574353
01/07/10 10:17 PM
01/07/10 10:17 PM
ky
ky
engine compartment needed painted anyway
Re: any a-body turbo pictures? [Re: jamesc] #574354
01/07/10 10:20 PM
01/07/10 10:20 PM
3050lbs,461cube,1/3/4" headers threw full exhaust,full interior,10"tire with mono leaf spring and cal tracs,8.75rearend with 3.91gears,727trans with NO trans brake,92 octane gas and the best thing is had the car in vegas three years ago(mopars at the strip)drove it around alot temp never got pass 200degrees!!O and the radio works.
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574355
01/07/10 10:25 PM
01/07/10 10:25 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
No doubt a bad bad ride..... plumb in a turbo and watch 175 mph show up on the timing board, and 461 cubes is not a "small" block.....
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574356
01/07/10 10:33 PM
01/07/10 10:33 PM
jamesc Offline
jamesc  Offline
again it really looks like a clean ride and certainly goes fast as well. been a long, long time since i messed with "small" blocks but at 461" it's a little on the large size isn't it? not knowing much about them these days i would think something of that caliber comes with a bit of a price tag. seriously...not harping on your car just that turbochargers do wonders in the right hands. properly setup you don't need a lot of displacement, high dollar heads, valvetrain or compression. as long as the engine is up to it cranking up the manifold pressure will really open your eyes. i'm a little bias towards turbos though, the most fun i ever had racing was on this
Re: any a-body turbo pictures? [Re: joshking440] #574357
01/07/10 10:44 PM
01/07/10 10:44 PM
If i never said the cube and you seen the engine its a small block(distributer at the back)my plumping is internal. Ha Ha Ha
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574358
01/07/10 10:57 PM
01/07/10 10:57 PM
jamesc Offline
jamesc  Offline
your car's already fast but like Josh said, put a hair dryer on it and you'll look like this
Re: any a-body turbo pictures? [Re: jamesc] #574359
01/07/10 11:05 PM
01/07/10 11:05 PM
Ha HA thats way too easy for me,and dont want to look like that!!!!!!!!! hat.
Re: any a-body turbo pictures? [Re: jamesc] #574360
01/07/10 11:32 PM
01/07/10 11:32 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I love my car, but there was a dude on here who did some turbo stuff to a bone stock 318 dart. It runs faster than my car, with way less money.
I plan on doing a turbo for my 74 3/4 ton. I have a 400BB (7.5:1 comp) that is a low miler than purrs. I figure work out the plumbing, and it'll be a monster in no time.
Re: any a-body turbo pictures? [Re: dave571] #574361
01/07/10 11:40 PM
01/07/10 11:40 PM
Come on N/A guy's help me out here!!!!!!!Or am I the only N/A guy who spends some money to go fast the clean way?????
Re: any a-body turbo pictures? [Re: mr. 63plymouth] #574362
01/08/10 12:44 AM
01/08/10 12:44 AM
OHIO,CIRCLEVILLE
68DARTTURBO Offline
68DARTTURBO  Offline
OHIO,CIRCLEVILLE
Ok here we go turbos are not cheap they are a nitemare to plum the headers alone are 2000 dollars if you do them right!And no you cant make big power without good parts! It takes big RPM to get turbos to make boost and you are not going to do this with stock rods and pistons.If you do it wont live long so dollar for dollar a good n/a over a stock bottom end turbo motor makes good sence for someone wanting to race or go fast on a budget!!
Re: any a-body turbo pictures? [Re: 68DARTTURBO] #574363
01/08/10 05:08 AM
01/08/10 05:08 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Not true. 2000 dollars for headers? Who does your work? You might wanna shop around.
And just how much does an Indy headed 461 cubic inch small block cost nowadays? 10,12,15,18 grand? Maybe you can, but the majority of people cant just drop that much on a motor. There are 550 dollar turbos on 360" motors running mid 8's on 10 inch tires. To me, that is impressive.
As has always been the case, most Mopar guys are scared to "step outside the box" and come to the "dark side"
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
