Where to get Neon PS belt tensioner pulley? #573980
01/05/10 06:04 PM
01/05/10 06:04 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
The PS belt tensioner pulley on my sons 01 neon locked up and we can't find a replacement WO buying a whole tensioner assembly. Does anybody know where to buy a replacement pulley?
Re: Where to get Neon PS belt tensioner pulley? [Re: wedgeheaded] #573981
01/05/10 08:31 PM
01/05/10 08:31 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
You can usually buy replacement bearings for those at NAPA or carquest. Just hammer the bearing out and press in a new one. You will probably need an experienced parts guy to know the part # needed unless you can get any numbers off the current bearing.
Re: Where to get Neon PS belt tensioner pulley? [Re: wheelsup68dart] #573982
01/05/10 09:01 PM
01/05/10 09:01 PM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
In my case ('03 Neon), the pulley shattered and threw the belt. I discovered in the U-Pull that I have to remove the engine in order to remove the tensioner assembly, so I can replace the pulley!!! It is about time for a new timing belt anyhow, so soon... in the meantime, I'm driving without power steering. Yep, I'm getting plenty strong! :lol:
The Hollander manual says timing belt replacement while installed, and I just DO NOT see anyway to do so!
Mike Bynum
Re: Where to get Neon PS belt tensioner pulley? [Re: dodgedartgt] #573983
01/05/10 11:02 PM
01/05/10 11:02 PM
Friendly, WV
Friendly, WV
We drove this WO PS to get it home but that's hard on the PS rack. There's a chunk missing from mine too. I have a friend who has his own repair business, he's doing the fix for me. We're just trying to save some money. Timming belt and WP replaced about a month ago. I like the new bearing idea in the previous reply, if my pulley is reusable missing a chunk.
